| Digitizing and Laser Digitizing Discuss Digitizing parts via Laser or otherwise here! |
#13
| Originally Posted by itsme
When I get a chance I'll post a picture of the amplifier I built and a drawing of the PCB board. I made the PCB board on a mill so it's quite easy to make if you can get the components. Mark Hughes Tooling. |
#14
| Hi Mark, Thanks for the information. If (when) I'm going to make the probe, I may as well do it all properly. If you could post pictures of your PCB, that'd be great. The other photos you posted are also awesome. I'm inspired to build a probe!!! Regards Warren
__________________ Have a nice day... |
#16
Thanks for the link, Pablo. Isn't it strange how the Renishaw innards look so similar to the probes that people build at home??? I've been looking at the amplifier schematic and I've been having a few thoughts on how I can adjust it to suit my requirements. With my CNC setup, I'll have a 35VDC supply. It would be nice if I could put the probe electronics inside my CNC control box and then use my CNC machine power supply. Would the probe be able to handle 35V? I doubt anyone has tried it, but what do you think??? I also have a few questions relating to the actual amplifier running at 35V, but I felt that these would be better placed in the 'General Electronics Discussion', so I am going to start a new thread there (just in case anyone is interested...). Regards Warren
#17
| well the probe is a simple on-off switch, if the current is not very high I see no problems. the problem is how do you feed 35v back to the parallel port ![]() IMHO is easier to use a proper voltage power supply, switching cellphone chargers are a very cheap source of power supplies, they usually have a pot inside that sets the output from 4 to 12v Pablo |
#18
| Hi Pablo, If you have a look back in one of the earlier posts in this thread (from hughesbros), you'll see the plans for a probe and also the amplifier that goes with it. The probe in those plans normally operates off 12V, which is also too high for a parallel port - that's the purpose of all the circuitry. All I want to do is modify that circuit to run off 35V instead of 12V. Why do something the simple way, when you don't have to... Regards Warren
#19
| I don't see why you need extra supplies when you have them in the PC if that is what you are using? Al.
#20
| What about using a piezo as the transducer? STMs use a piezo tube to move the probe across the suface. See this homebuilt version; http://www.e-basteln.de/ renishaw has piezo probes; http://www.renishaw.com/client/produ...PGP-1070.shtml Or maybe look at an AFM; http://www.nano.geo.uni-muenchen.de/...3_document.htm |
| Building a stepper motor. | tastefulasever | Stepper Motors and Drives | 13 | 12-11-2009 10:50 AM |
| Pop-up tool touch probe | dmealer | General Metal Working Machines | 4 | 04-04-2005 06:47 AM |
| Digitizing probe question for newby | Kitch02 | Digitizing and Laser Digitizing | 6 | 03-30-2005 07:18 PM |
| Tool setting probe | JFettig | Mach Software (ArtSoft software) | 18 | 03-12-2005 07:33 AM |
| DeskCNC TP-100 Probe released | imserv | Product Announcements & Manufacturer News | 7 | 03-11-2005 08:10 AM |
