Who want to make a touch probe? - Page 3
Page 3 of 6 FirstFirst 123456 LastLast
Results 41 to 60 of 120
Thread: Who want to make a touch probe?
  1. #41
    S.N.A.F.U. miljnor's Avatar
    Jan 2005
    well the picture isn't all that clear on your web sight.
    So just to clear it up.
    The coin/penny is drill thru and the bolt goes thru it?
    this then rests on the pin heads for contact?
    The spring pushes down on the penny/bolt for adjustment?
    And the silicone is for keeping the penny from sliding around?
    And from what I gather the silicone goes around the prob inside of the shaft hole underneath the pins???
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
  2. #42
    Registered 10bulls's Avatar
    Feb 2005
    UK
    Quote Originally Posted by miljnor View Post
    Sorry, it had been drinking, I'll have words with it.
    Yes, so that the head is against the top (unfaced face).
    Yes, like a dolmen.
    Yes
    Yes. To be honest, I haven't put any on the prototype, but I thought it would be a good idea as if the probe gets pushed sideways the disk
    can rub against the inside of the cylinder and hang.
    I would put it outside. That way you can put it on afterwards when you're happy it's working. Or you could use a small piece of silicon tube maybe.
  3. #43
    Gold Member
    Jun 2003
    10Bulls is it still working? Are you gonna post plans?
    Mike
    No greater love can a man have than this, that he give his life for a friend.
  4. #44
    Member greybeard's Avatar
    Jun 2005
    UK
    10 bulls - just a thought. Had you considered substituting a small cylinder of foam rubber for the spring ?
    I see the spring as being asymetrical in its pressure on the penny, and the foam could also act as a seal above it. The foam could be stuck to the penny for location, and a second piece underneath the pin assembly could as as a lower dust seal.
    John
    It's like doing jigsaw puzzles in the dark.
    Enjoy today's problems, for tomorrow's may be worse.
  5. #45
    Feb 2005
    UK
    Quote Originally Posted by turmite View Post
    Yes, the scan completed with not one hang. The plans (such as they are) are on on the web link in post #39.
  6. #46
    Feb 2005
    UK
    Quote Originally Posted by greybeard View Post
    Yes, in fact MrBean's Mk I probe had a piece of foam for a spring.
    It would certainly work and I like the idea of gluing it to the disk to help prevent sideways movement.
    The design lends itself to tinkering and using what's lying around.
  7. #47
    Member sdantonio's Avatar
    Nov 2005
    Quote Originally Posted by svenakela View Post
    All the commercial scanners and computer controlled measuring systems uses tools with ball tips. Shouldn't be a big problem to put a ball bearing ball at the end of the tip.
    Actually I had a brilliant idea the other night. Traditional violin makers, when they see an instrument where they want to preserve as much information as they can, make up a plaster mold cast directly from the instrument. Modern materials allow us to use a combination of silicone rubber (which will not stick to varnished surfaces) and urethane polymer to make the final casting.
    A violin maker I know in NYC tells me that his sillicone/urethane castings come out so accurate that they preserve even the smallest imperfections in the surface like chipped varnish, etc.
    So I make a urethane casting, then use the touch prove on that. And I can be as rough with that as I want. Couldn't be simpler.
    If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do?
    Steven
  8. #48
    Feb 2006
    Quote Originally Posted by sdantonio View Post
    Where do you get the casting material? Any brands you prefer?
    Vince
  9. #49
    Nov 2005
    This is my source for urethane and silicone rubber http://www.jgreer.com/ There was a paper published a couple of years ago in the journal of the violin society of america detailing the process (actually it is the transcription of a talk given by a violin maker from NYC of the method he uses. Prior to these materials it was plaster castings. I used to have a hard copy before the big hard drive crash of last summer (damn maxtor). This isn't the same paper but I found it with a quick google. http://www.abcviolins.com/moulds1.html
    Steven
  10. #50
    Nov 2005
    Oh yeah Vince. Always test on scrap wood first (john's source material sometimes changes).
    Steven
  11. #51
    Member arie kabaalstra's Avatar
    Jan 2007
    Netherlands
    intresting Topic, i get the picture, i'll start working on my own little probe..
  12. #52
    Dec 2006
    Italia
    idea!
    It is possible to place this switch in the top of the Indicator and the design could be simplified.
    Regards.
    Se le puede colocar este interruptor en el tope del indicador y se pude simplificar el diseño.
    Saludos.
    Tactile Switch (tipo mouse): http://www.jameco.com/webapp/wcs/sto...oductId=119010
    Attached Thumbnails Attached Thumbnails Who want to make a touch probe?-tactile-switch-jpg
  13. #53
    Jan 2007
    Netherlands
    i'm not sure this will work, since it can only switch when pressed on, , and how are you gonna design a system that triggers the switch, nomatter which way you move the probe?..
    anyways, to make a long story short, i've made my own probe already only 25 mm in diameter, repeatability within 0.005 mm, so i think it's accurate..
    http://i12.photobucket.com/albums/a2...1/DSC_0473.jpg
    http://i12.photobucket.com/albums/a2...1/DSC_0462.jpg
  14. #54
    Jan 2007
    Japan
    Quote Originally Posted by Giacco View Post
    idea!
    Regards.
    Saludos.
    I ripped apart a few computer mice the other day looking to grab some parts for my new edge detector/probe. I had three Logitech mice and they all used OMRON mini-switches. I think it would be hard to adjust as there is quite a bit of hysteresis between off and on.
    Looking at other parts of the mouse though the X-Y IR detection circuits are interesting. I am going to use a few of these positioned at 120 deg. and one on top of the probe shaft for Z-axis touch. With a small hole in the pcb about the size of a sewing pin it should work. Designing an adjustment method now.
    Attached Thumbnails Attached Thumbnails Who want to make a touch probe?-omron-ir-jpg
  15. #55
    Dec 2006
    Italia
    Esta es mi idea
    This is my idea
    Saludos.
    Attached Thumbnails Attached Thumbnails Who want to make a touch probe?-scannercnc-jpg   Who want to make a touch probe?-scannercnc-pdf
  16. #56
    Gold Member
    Jun 2003
    Hello Giacco,
    Beautiful design.......but I see a potential problem. Your probe has no clearence for side to side movement and will only work in straight up and down probe movement. Some of the scan software has a feature that uses the side of the probe tip as much or more than it uses the end. I have a commercial probe and it has about 2mm clearence all the way around the probe shank where it comes out of the body of the probe. When using an extension for a total of 2" of shank I have quite a bit of overall movement at the tip when pressed from side to side. This allows for overtravel and helps to keep from damaging the probe while in use.
    Mike
  17. #57
    Jan 2007
    Netherlands
    that's why i think a 3point setup is the best ( and i made my drawings just for that setup ), the slightest motion wil cause any of the 3 switches to break circuit, and thus giving the control a sign "hey!!.. something's touching!"
    if you increase the diameter of the disc that operates the switch, it might even do "side probing" but i'm not sure it will be very accurate..
  18. #58
    Dec 2006
    Italia
    Es verdad, ya comprendo el funcionamiento.
    It is true, already I understand the functioning.
    Regards.
  19. #59
    Dec 2006
    Italia
    Second Prototype, changing concept. The sensibility might be controlled by means of the screws of adjustment. The circuit would be closed to the contact from any side. Suggestions please.
    Regards.
    Segundo Prototipo, cambiando concepto. La sensibilidad se podría controlar por medio de los tornillos de ajuste. El circuito se cerraría al contacto desde cualquier lado. Sugerencias por favor.
    Saludos.
    Attached Thumbnails Attached Thumbnails Who want to make a touch probe?-sensorscan2-jpg   Who want to make a touch probe?-sensorscan2-pdf
  20. #60
    Mar 2004
    Sweden
    Giacco, I really like your engagement in the topic, but I think it's not the best solution.
    The problem is that if an unexpected hit occur, the tip will be bent. The design with three pair of balls is a lot more flexible. Also it's self-aligning, the tip will be forced to fall back to same position even after a big move.
    The big CMM companies also have flexible tip tools that allows several millimetres of travel.
    Regards,
    Sven
