Results 1 to 2 of 2
Thread: steel rule die through plastics?
    Mar 2008
    I'm hoping to cut plastic with steel rule dies. Is this going to work out? We're looking into different plastics .035" - .08" thick is a steel rule die going to be able to get through that? What plastics would be best to work with (also have to be easily injection moldable). Please give me some thoughts.
    Thank you,
    Brad Leong
    Nov 2003
    Pennsylvania
    Steel rule can handle it but plastic is abrasive so it will only last so long before resharpen or redo steel rule die. You need a well trimmed clicker press to get good cuts. Size??? Dimensional tolerance?
    The plastic depends upon what you need to do with the part afterwards. Fit finish etc is a factor in this. Way too many plastics out there to say 'this' is what you need.
    What does injection moldable have to do with the steel rule die??? Something in the process is not right.
  1. Steel Rule Automatic Bender
    By ddanutz1 in forum Diemaking and Diecutting
    Last Post: 03-18-2012, 03:10 PM
  2. steel rule dies
    By anchange in forum Employment Opportunity
    Last Post: 10-21-2009, 03:01 PM
  3. Tips for making simple steel rule dies
    By leathersmith in forum Diemaking and Diecutting
    Last Post: 09-25-2007, 04:31 PM
  4. I'm looking for a foot power steel rule bending table
    By richtx7 in forum Bending, Forging,Extrusion...
    Last Post: 09-08-2007, 01:53 AM
  5. Steel Rule
    By pp-TG in forum Diemaking and Diecutting
    Last Post: 05-25-2007, 04:39 PM
