Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Diemaking and Diecutting
Diemaking and Diecutting Discuss Diemaking and Diecutting here.
Old 07-01-2009, 12:31 PM
dminnich is on a distinguished road
Press bed skew
Is it OK to shim a press bed that is bowed about .015"
I get conflicting answers.
I cannot afford to send the entire press out to be re-machined.
Old 07-06-2009, 09:59 PM
johnd is on a distinguished road
Press bed skewed
It depends on what you are cutting with and the exoected life expendancy of the tool.
What is the distance of the .015 bow?
Are you cutting with steel rule?
If you are cutting with steel rule what are you using as a consumable surface?
Are you using a die set?
If so is it a two post or four post die set?
Need a little more information to help you out.
Been there and done it,
JohnD
Old 07-07-2009, 06:46 AM
Press bed skewed
The bed is about 40" accross and is bowed the entire distance with the center being down .015"
I checked it useing a precision starrett level and feeler gauges.
We use die sets but cut thin materials, with more than one layer at a time.
(Usually .012" aluminized, .001" aluminum foil, and .015" 409 stainless steel)
Die sets are four post
Thanks for the reply, hope the information helps
die for a press Eagle23 Diemaking and Diecutting 2 06-21-2009 02:55 PM
NEED MOLD PRESS HELP BAD DOG Moldmaking 5 02-09-2009 09:48 AM
NorthStar Press Brake For 20 Ton Shop Press anyone ever use one? dsmdude Bending, Forging,Extrusion... 6 04-13-2007 05:01 PM
PRESS Size? ZipSnipe Diemaking and Diecutting 18 12-07-2006 09:52 PM
Q: Press Fit Deviant General Metalwork Discussion 6 09-11-2006 02:20 AM
