Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Diemaking and Diecutting
Diemaking and Diecutting Discuss Diemaking and Diecutting here.
Old 06-03-2009, 05:59 PM
Eagle23 is on a distinguished road
die for a press
Hi
I would like to make a die for a press
If you look at the picture
I have numbered the parts that will have to be soldered to the main block
Since making a die is a precise method
I will have to have this done very professionally
Can anyone recommended a method for soldering
For sure I have to have the parts fit in very tightly
Are there other techniques I should know
Also What kind of solder should I use
Sorry I could not upload the pictures I will do that another time
But I think you can understand what I mean
I have to solder pins and a cylinder in the center
Old 06-04-2009, 03:06 PM
capital is on a distinguished road
Eagle,
I sent you a message with email address. Feel free to contact me with more info and I will try to help.
Old 06-21-2009, 02:55 PM
brianm1 is on a distinguished road
stamping dies
eagle
I have 26 years die making experience .
Let me know if I can help you.
Brian
drill press mod tbenefi33 Wood Lathes / Mills 1 02-24-2009 05:49 AM
press fit woes kendo General Metalwork Discussion 19 08-12-2008 10:44 PM
Build Thread- What Can You Do With A Arbor Press? captainlee Mini Lathe 0 03-03-2008 06:08 PM
NorthStar Press Brake For 20 Ton Shop Press anyone ever use one? dsmdude Bending, Forging,Extrusion... 6 04-13-2007 05:01 PM
Q: Press Fit Deviant General Metalwork Discussion 6 09-11-2006 02:20 AM
