Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Diemaking and Diecutting
Diemaking and Diecutting Discuss Diemaking and Diecutting here.
Old 09-24-2008, 09:46 AM
dcis77's Avatar
dcis77 is on a distinguished road
Speed & Feed Rate?
Hello to all!
I am new in this forum and I would like to help me in a minor problem!
I have a hole 8.5mm and I would like to make a tap (M10). The depth of the hole is 22mm.
What will be the Speed and the Feed Rate?
Thank you in advance!
dcis77!
Old 09-25-2008, 11:37 AM
jjasshipley is on a distinguished road
M10 x 1.5 ISO Course thread
M10 x 1.5 thread. A good starting point would be 196rpm and 9.8 ipm.
Old 09-26-2008, 01:49 PM
dcis77's Avatar
Thank you jjasshipley!
Old 09-27-2008, 04:57 AM
dcis77's Avatar
One Question again!
I have a carbide 16mm with 6 flutes (50mm long).
I want to pass around a piece of steel to take 0.1 lateral oversize.
I use 1800 RPM for Speed and Feed Rate 400. Is this correct?
It is very noisy with these values. My cnc-machine is "screaming".
What Spindle Speed and Feedrate is recommended?
Thanks again!
dcis77
Old 11-13-2008, 11:29 PM
Konrad's Avatar
Konrad is on a distinguished road
If it's screaming like this the carbide tool doesn't last.
You can try slow down RPM and increase feed.
Or using a high speed tool, and slow down RPM.
Konrad
Need Help!- Feed Rate and Spindle Speed chart? jeffmorris DIY-CNC Router Table Machines 3 06-01-2008 10:42 PM
CNC feed rate and spindle speed misc.garfield General CNC (Mill and Lathe) Control Software (NC) 5 01-29-2008 06:20 PM
Feed rate and Speedle speed for M4-.7 tap chakaloso Haas Mills 9 09-20-2007 04:52 PM
surface speed and feed rate calculator derkiow General Metalwork Discussion 9 06-04-2006 08:33 PM
Spindle speed & feed rate on a Taig Stuff-Builder Taig Mills & Lathes 5 08-29-2005 06:01 PM
