Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Diemaking and Diecutting
Diemaking and Diecutting Discuss Diemaking and Diecutting here.
Old 09-13-2008, 10:58 PM
Mcyoda is on a distinguished road
Stamping Press For Sample Square Lids
I have a few questions and like to know is possible to do all this in one single stamp punch. The parts I like to do is very 4" x 4" x 1/4" lid and is 20ga 304 stainless steel. I like to have a very tight edge bends and 90 degree all sides.
1. Is possible to do all these with single punch that include 4 corners notch out and fold back the 4 sides?
2. What size or type of stamping press will work for this type of work? I looking for high speed run.
Old 01-20-2009, 11:29 PM
PhoenixMetal is on a distinguished road
No, you cannot punch out the corners and do the bends in one press stroke. This will be done in a minimum of two strokes: First to punch out the corners, and second to do the bends.
However, unless you need to do a whole lot of volume (maybe 5,000 pieces or more), you are better off doing the bends on a press brake one at a time instead of investing in an expensive die to wipe all four flanges at once.
Regarding the tonnage needed, pretty much any press can handle this - you are not talking about any significant tonnage requirements. For punching the corners out, if you are starting with a blank that is already the exact size you need (minus the corner cutouts), you would only need around 5 tons to punch the corners out.
Old 02-06-2009, 01:59 AM
metalworkz's Avatar
metalworkz is on a distinguished road
Mcyoda,
Are you talking about a draw-form tool to form a 1/4" flange all around the cover without any corner notches?
Regards,
Regards,
Wes
Old 02-10-2009, 02:03 PM
juergenwt is on a distinguished road
Look up "Pinch Trim Die". Used to combine drawing and trimming in one operation.
swipe stamping? Med-Pac Diemaking and Diecutting 4 01-25-2009 02:34 PM
Stamping? dal Casting Metals 5 09-21-2008 01:22 AM
Time Stamping CNC Programs kballance Fanuc 3 05-27-2008 04:30 PM
NorthStar Press Brake For 20 Ton Shop Press anyone ever use one? dsmdude Bending, Forging,Extrusion... 6 04-13-2007 05:01 PM
stamping MBG Bending, Forging,Extrusion... 47 10-19-2005 08:48 AM
