Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Diemaking and Diecutting
Diemaking and Diecutting Discuss Diemaking and Diecutting here.
Old 06-20-2008, 12:54 PM
PhoenixMetal is on a distinguished road
CNC diemaking shop needed to build tooling from my SolidWorks models
I have designed several dies in SolidWorks and need to find a CNC toolmaking shop that can produce from my 3d models.
All the diemakers that I know of are old-school - they need two months to make anything and do their work with hand-fed milling machines, and they work only with 2D cad and don't know 3D modelling.
I'm looking for a shop that can take my SolidWorks models, program their CNC milling machines, machining centers or EDM, and turn out a part to my specifications in a short amount of time.
Does anybody have this capability or know of a good shop for this?
Old 06-20-2008, 01:37 PM
bostosh is on a distinguished road
Would like to help
Being new / old school student, teacher and practitioner, I have to ask.
Is this job capable of being done 2-D?
The old school may be cheaper and better.
or involve complex 3-D cavity contouring, x,y,z size,
shot volume, runner design, ejector pins, slides, threads, plastic, or zinc/aluminum metal, over/under rockwell 64, tooling budget, ??? etc.
Much depends upon the part you wish to produce and the quantity. Sure, I have worked on molds for Detroit which were guaranteed 500,000 cycles and Aerospace concept molds used 5 times. Or even Space Shuttle tooling for three parts, then throw away the tooling. There are many ways to accomplish your parts.
Please, I need more information to be of assistance.
Brian O
Been doing this too long
Old 06-20-2008, 02:41 PM
HI Brian,
Well yes this is certainly doable in 2-D, but it is just so much more difficult to communicate back and forth and so much harder to make and communicate changes in the 2D when one person is working with a solid model, and the other with 2D AutoCad.
Plus if I knew that the part was being made via CNC directly from my models, it would give me much more confidence in my ability to mix and match these die components with other tooling components that I already own, or which are off-the-shelf components - knowing that holes will line up just right, and clearances will be exactly as specified.
So by all means, an experienced old-school toolmaker can certainly make what I need, and maybe you are the right person to do this, and for certain when it comes to toolmaking I know that experience is everything... But I just have more faith in CNC processes to produce exactly what is on my computer screen.
I can PM you further details of what I have in mind if you are interested.
Old 07-17-2008, 06:26 PM
firepoker1965 is on a distinguished road
Take a look at the site MFG.com.It is free for buyers so maybe it can help you.Let me know what you think.It does look interesting.
Tony
Old 07-17-2008, 07:14 PM
PhoenixMetal
If your die design is totally perfect as wanted in Solidworks,
just reduce it to drawings with tolerances,
Cad models need a translator to the shop,
Thats what I do, speak both languages.
Detailing and machining from CAD
Am I understanding what you need?
Old 07-17-2008, 11:39 PM
warrenb is on a distinguished road
I am sure i can help. PM with the solidworks model (or XMT, STEP, IGES) or the finished part and I can take a look. I produce many molds using many different models.
a few things we'll need. Shrink, tolerances, and material.
Warrenb
Old 07-18-2008, 11:04 AM
Tony
Thanks Firepoker,
That actually looks like it might be a good site. Kind of like Alibaba in a way, but it looks like this site gets more involved in the quoting process, rather than just being a place to make connections. And it seems to be US-centric, rather than primarily for suppliers in China. I might have a use for that someday.
Thanks,
-PhoenixMetal
Old 07-18-2008, 11:08 AM
Originally Posted by bostosh View Post
PhoenixMetal
Hi Botosh,
Yeah, you do have a good idea for communicating Solidworks models with 2D folks... Especially since in Solidworks once you make a drawing from a 3D model, the 2D drawings automatically update themselves with new changes to the 3D model.
Old 07-18-2008, 11:30 AM
I worked with a small tool shop where we made the die blocks all on cnc mill and wirecutting machines.Even the die sets and subplates were done on the cnc mill.We used Mastercam software which is used with Solidworks.Things did not always go perfectly but then it never does!
Good luck.
tony
Old 01-02-2009, 03:00 AM
michaeljmorrow's Avatar
michaeljmorrow is on a distinguished road
i work at a old school tool and die shop we do alot of things old school are competion is one of the largest they have fully automated robotic machines that cost millions there constantly dumping money into there buisness to try and do what i do on machine that come out in the 60s if it works y replace em anyway 3d is fine but pretty much you very seldemy ever realy need it ur third dimension is only depth people think of 3d there like oh god its definatley harder to draw but in most cases i dont because its not needed cost extra although we have cnc lathes mills several diferent types of edms cnc grinders we have the equipment but its hard to make money on something unless there a return customer somebody who wants to set up a contract for these parts are draftsman and cnc programer also has some real good tricks on converting those solid works drawings makes it compatible with are equipment we dont use solid we use bobcad mastercad mostly i meet be able to help u more if i knew a lil more about the die
  #11   Ban this user!
Old 01-02-2009, 12:33 PM
Well Micheal ,I'm not really sure I understand your point but if you need some dies built from SolidWorks I can do that for you.
tony
  #12   Ban this user!
Old 09-02-2009, 05:18 PM
roninB4 is on a distinguished road
If it's a stamping die then 2D will be just fine in almost all circumstances. I do 3D modeling (Pro-E) and it is beneficial when creating parts but unless it's a mold I don't see why it's required. Most of the machining work I did for molds was also in 2D with a small number of jobs that had Z axis profiling in the core/cavity. Accuracy is not solely the domain of CNC either, if the machine is incapable of holding tolerance then your design won't be reflected in metal. CNC centers get worn out like any other machine. Your targeted design has to fall within a budget constraint doesn't it? So perhaps it really shouldn't matter how that was achieved so long as intent was realized and falls within the budget you've set. If you're uncomfortable with "old school" methods then you'll never know when to use them or discard them. Technology isn't everything, results are. JMO, it's your time and money.
Relief models needed kong General CAM Discussion 15 12-03-2011 04:41 AM
CNC Shop - Mig & Tig Welder needed lbi17 Employment Opportunity 2 11-13-2007 12:00 PM
Book about diemaking and diecutting Sperstad Diemaking and Diecutting 2 06-24-2007 02:05 PM
Home Build CNC for School shop. mwalach CNCzone Club House 39 06-05-2007 08:49 PM
