Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Diemaking and Diecutting
Diemaking and Diecutting Discuss Diemaking and Diecutting here.
Old 04-09-2008, 08:23 PM
salvaCNC is on a distinguished road
What depth do you suggest?
I need some help trying to determine what would be the right depth for my first attempt on a die.
In my first trial I gave it a 2mm depth to the pattern, but it took me forever to make it (several days).
In my second attempt I reduced the same pattern to 1/2 mm depth, but it hardly made a dent on the stamped material. This second die took me 6 hours to make.
The pattern is half spheres.
What depth would be sort of close to a mean average in the industry for trial purposes? I do not want to spend several hours and wasting more material and machine time. Thanks.
Old 04-09-2008, 10:06 PM
Chuck Reamer's Avatar
Chuck Reamer is on a distinguished road
What kind of a die is it? Are you stamping or forming or both?
We need a little more description if you want a little help.
Live free or die
Old 04-10-2008, 10:04 AM
Thanks for the reply.
I am trying to make a stamping die. The figure I am trying to stamp is a basketball and the pattern I mentioned is the little half spheres from the ball.
The stamped material is an EPS foam 5 mm in thickness.
I have a attached a picture of the press I am using (the small one). It is a roller press.
Even though I regulate the pressure of the roller to the point I cannot insert the material + the die, I am still not getting a clear impression.
This is the reason of my question, how deep should I go in my die for a decent clear print ?
Thanks again
Old 04-10-2008, 10:07 AM
wow kinda a cool application you have going on there, unfortunately I cant help you my experience is with alloys and large punch presses.
Live free or die
Old 04-10-2008, 10:31 AM
What depth do you give you allows though?
Suggest a CAD package for me? JayH1119 General CAM Discussion 7 01-04-2008 09:51 AM
Suggest a VFD bcromwell Phase Converters and VFD 1 04-20-2007 11:11 PM
Suggest some software! Please disinformation General CNC (Mill and Lathe) Control Software (NC) 2 01-13-2006 04:16 AM
Someone suggest a machine!! leewinn General Metal Working Machines 0 11-21-2005 11:53 PM
Can any suggest CNCadmin CNC Wire Foam Cutter Machines 4 04-06-2004 11:23 PM
