| Diemaking and Diecutting Discuss Diemaking and Diecutting here. |
Hello All: I want to die form a 16ga. mild steel sheet metal box 6" x 6" x 1". I have a hydraulic bending brake. I want to build a hydraulic die forming press to do the bending all at once. The die is used to fold the sides. A hydraulic bottle jack will power the press. What size bottle jack I need, 20, 30, 50 ton? Best regards, Andrew Last edited by andrew888; 02-07-2008 at 05:53 PM. Reason: continuation |
| Hello All: Maybe a deep drawing die will work. I want to do polygonal metal boxes with 1" depth sides as well as square. I am new to die forming but I learn easy. I waiting for help. Thank you for future help, Andrew |
| how many box's are you making? sounds to me you already have a press brake you will need to make fingers the size of the inside of the box sides and set up stations on your press i don't think bending all four sides will work the way you want it to you wont be able to over bend the side, they will spring back slightly |
Hello holbieone and all: Now I can talk to someone real. 100's of boxes square, pentagonal hexagonal, etc. You say "will spring back slightly", and I know that you are correct. How do manufacturer make metal boxes? Being a newbie what are stations? If this process is fast I will go that way. Thank you the dialogue, any help will be appreciated, Andrew |
| bend 2 L shaped plate and spot weld all unwelded sides. If you want in one go, use what is called as goose neck or swan neck die.Put the word in Google and you'll get hoards of pictures. Still you want the boxes to be made and sent, can contact me
__________________ Chan Luci, Techie www.custompartsonline.com |
Chan Luci and All: Could you send pics of L plate and their arrangement. I have googled the gooseneck dies. I need to see the process of making the boxes all at once using the above arrangement. This is diy appropriate technology. In other words I don't have much money. Ingenuity and little help from my friends like you. Thank you, Andrew |
| I'm bascially in the business of making metal boxes. Unless you need rediculously large quantities (and if you do, a bottle jack powered press isn't the thing to do it with), the way to go with with segmented tooling (normal V press brake tooling) on a press brake. This will be done in 4 hits. Basically, you need a small segment of a top punch that is just under 6" long. You need to create a backgauge that positions the workpiece so that the flange ends up at 1" high. If you don't have a 6" segment, consider taking an old longer piece of press brake tooling, and cut a segment off of it. You can buy used tooling on ebay and cut it to the length you need. If your press is a shop press (bottle jack type) and not a press brake, consider making a die holder in it to hold normal press brake tooling. This method is much faster and requires much less upfront costs than deep drawing, or making a die to bend all 4 sides simultaneously. |
| Sheet metal forming on a CNC mill... | BobWarfield | General Metalwork Discussion | 20 | 07-03-2009 06:35 AM |
| Metal roof forming stamping? | DennisCNC | Bending, Forging,Extrusion... | 7 | 06-28-2008 10:49 AM |
| Build cnc router without linear ball bearings ?? Flat metal on flat metal with lube ? | vroemm | Linear and Rotary Motion | 7 | 08-16-2007 01:26 PM |
| Wire forming | zcases | Employment Opportunity | 3 | 11-16-2006 05:17 PM |
| Thread forming | crayner | General Metalwork Discussion | 6 | 03-24-2006 08:24 AM |
