Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Diemaking and Diecutting
Diemaking and Diecutting Discuss Diemaking and Diecutting here.
Old 02-15-2006, 02:08 AM
ZipSnipe is on a distinguished road
PRESS Size?
What size (tonnage)press whether arbor or hydraulic would I need to punch out shapes in copper and aluminum approx. size 139.7mm X 66mm X 0.5mm ?
Old 02-15-2006, 09:04 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
It's a straight forward calculation based on the shear strength of the material and the perimeter of the cut. Don't forget to factor in the thickness.
Does that help? I am no expert, but I see nobody has replied and I have jumped through these hoops before so I thought I would chime in....
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 02-15-2006, 11:21 AM
Well thats better than nothing response. I,d be glad to do the calculations if I could find the shear strength of copper and aluminum at .5mm thickness.
Old 02-15-2006, 11:35 AM
ViperTX is on a distinguished road
So, according to my Machinist Handbook the 'rule of thumb' is:
Round Holes:
steel diameter x thickness x80 = Number of Tons
brass diameter x thickness x 65 = Number of Tons
Any other Holes:
steel Perimeter x 1/3 x 80 = Number of Tons
brass Perimeter x 1/3 x65 = Number of Tons
Old 02-15-2006, 12:39 PM
mxtras's Avatar
Silver Member
Aluminum Mechanical Properties
ALLOY AL 6061T-6
Tensile Strength (ksi) 45
Yield Strength (ksi) 40
Elongation (% in 2") 17
Shear Strength (ksi) 28
Hardness (Brinell) 30
Scott
Old 02-15-2006, 09:10 PM
Thanks guys looks like I,ve figured around 5 1/2 tons to press out what I want and I figured purchasing a 10 or 20 ton press should work.
Old 02-15-2006, 11:35 PM
ZipSnipe...keep us updated on your progress...maybe even some pics...
Old 02-16-2006, 01:35 AM
Unfortunetly it won,t be until March or even April till I purchase any new equiptment however in the mean time I,m doing mega research on cnc, and everything I need to do metal fabrication (copper and aluminum) once again appreciate the help. And of course I,ll supply pics.
Old 08-29-2006, 02:14 AM
gbowne1 is on a distinguished road
Well, it appears I need at least a 35 ton press to do the work I need myself.. but a punch press of substantial quality is going to be procured. I'm still working with a press manufacturer to design a single station press that has a bolster plate that I want so that it holds a single 28xx setup.. and will allow me to fixture parts to the plate up to indexes / stops. This will be a 2nd operation press.
I used to run a monster press.. a Heim Rouselle G1-55 55 ton OBI press at the shop I used to work at. Most of the 6" x 12" dies were about 35 ton max. It's a wonder how the press never broke the dies.. being 20 tons over max.
I had our AMADA CNC turret press operator/set up guy punch out parts that I was rejecting a lot do to ill-constructed dies. No matter how much we sharpened and lubed the dies, they wouldn't cut 100% perfect parts. Parts such as 1" x 1" thin aluminum squares with a small oblong slot in them were the worst cause they would get stuck in the die cork all the time. Parts like that would take me hours to press out, in what he could do in minutes.. and literally hundreds of them.
Basically before you go on to your manufacturing make sure you got a good die design, that your tonnage is right, you are properly lubing your stamping dies and mat'l, make sure you are using a good stripper and your clearances are right. You can always call Danly or Lempco.. and they'll help you.
Greg
Old 08-29-2006, 05:16 AM
Thanks for the response Greg, but I have since changed direction on the product i was going to produce. But it was nice to learn what it would take to make the part.
  #11   Ban this user!
Old 08-29-2006, 05:15 PM
I knew this thread was a little old but well, even if you had done something else with your project, I wanted to post my $2 worth because you will never know whom may read the thread and need the information.
Greg
  #12   Ban this user!
Old 08-29-2006, 08:10 PM
Good point the more info people can pick up the better.
