Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Diemaking and Diecutting
Diemaking and Diecutting Discuss Diemaking and Diecutting here.
Old 06-06-2011, 07:00 AM
Kevinoh is on a distinguished road
Cutting Clearance for PCB stamping
HI there,
I have just taken on a nice little job to make a tool for releasing multiple component assemblies from a PCB (printed circuit board) and was wondering if anyone had any advice on the cutting clearances for optimal tool life?
The PCB is 1.2mm thick and uncoated.
I did a test piece in an other tool with 0.025/side clearance and the edge was pretty clean but I have no idea how long the edge will hold up, wether PCB is abrasive etc etc. I have spent a few hours trawling the net but can't find any data whatsoever.
Any ideas or experience would be great...
Old 06-06-2011, 08:06 AM
Gold Member
RomanLini is on a distinguished road
I don't have any experience with punching shapes out of PCB, but if it is fibreglass PCB it is very abrasive to tools. Carbide tools last longer although I doubt you can machine your punch and die from carbide!
I have a hand-nibbler tool for PCBs and it is steel, but the steel has been hardened.
Maybe you can use high carbon steel and then have it hardened?
Old 06-06-2011, 08:37 AM
Thanks RomanLini,
We make a lot of carbide tooling here, but unfortunately we only quoted for tool steel. I was intending to use D2 hardened to 60-62 HRc, and get it TiCN coated, but now I know it is abrasive I might upgrade to ASP23 or some other sintered steel, maybe even CrN coat it too...
That still leaves me with the issue regarding cutting clearance though, I'm guesstimating about 6-7% per side at the moment.
Cheers for your input anyway
Kev
RFQ - cutting/stamping expanded metal badger1 RFQ (Request for Quote). 5 07-05-2011 06:27 PM
Need A Quote- Need 100 -150 ton stamping ability. sdjdave Employment Opportunity 7 09-29-2009 02:25 PM
swipe stamping? Med-Pac Diemaking and Diecutting 4 01-25-2009 01:34 PM
Stamping? dal Casting Metals 5 09-21-2008 12:22 AM
stamping MBG Bending, Forging,Extrusion... 47 10-19-2005 07:48 AM
