Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Diemaking and Diecutting
Diemaking and Diecutting Discuss Diemaking and Diecutting here.
Old 04-05-2010, 10:22 PM
fredk is on a distinguished road
Clicker versus roller press?
There are a range of manual bench top presses available such as the MA Series III Clicker press and GrandeMARK roller press and would anyone have experience comparing them?
Does anyone have experience trimming a MA Series III press? Would it be realistic to cut a large die and expect to get a clean cut? Would you just shim the base if needed?
How would the maximum cutting pressure compare?
Are roller presses less problematic in achieving a clean cut on a large die?
Tags
a series iii, grandemark
Need Help!- Selecting Press for home shop press brake tikka308 Bending, Forging,Extrusion... 0 12-28-2009 10:51 PM
Ease of use.. GibbsCAM versus Mastercam versus BobCADCAM, etc.? squale General CAM Discussion 4 11-10-2008 04:41 PM
Homemade die clicker with hydraulic press? leathersmith Diemaking and Diecutting 6 06-12-2008 05:01 AM
roller screw versus ball screw. Paraprop Linear and Rotary Motion 2 04-15-2007 04:21 AM
Mister versus flood versus ??? coolant system split63 Bridgeport and Hardinge Mills 14 10-02-2006 05:18 AM
