Results 1 to 5 of 5
Thread: Gasket punch
    Registered fatal-exception's Avatar
    Mar 2006
    Gasket punch
    Hey guys, just noticed that there is a forum here for this type of thing. Wish i would have know that before. Anyways, I had the job of creating a hand powered punch to make 3/4" holes in 1/8" thick neoprene rubber today. The handles should be a few inches longer. What else would you suggest to make this a nice tool to use?
    It works well. Die is hardened O1 tool steel, fully hardened. I've ground a fine edge on the cutter, even though it looks like .... in these pics. The other side is HDPE plastic.
    Paul
    Attached Thumbnails Attached Thumbnails Gasket punch-dscn2225.jpg   Gasket punch-dscn2226.jpg   Gasket punch-dscn2227.jpg   Gasket punch-dscn2229.jpg
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    looks good , how bout using some of that tool dip to soften up the handle for comfort sake , something like this stuff http://www.kk.org/cooltools/archives/000210.php
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    http://microcarve.microcarve.biz/
    Mar 2006
    Yeah, Rona sells Plasi-Dip, only place in Canada that I know of. I have some, but it's at the lake. Besides, to do a good job of it, a couple coats per day max. This tool is signed up for service tomorrow morning. Plasti-dip is fun to use though.... Even the wiener sticks have rubber handles now...
    Paul
    Oct 2005
    canada
    Quote Originally Posted by fatal-exception View Post
    Paul
    thats why I haven't bought any of that stuff yet because i know i'll go nuts with the stuff ,
    Dec 2004
    Do I have any suggestions?
    1) Wire spring preloaded to return the tool to the "open" position
    2) Testing the tool on something other than the blueprints unless that's supposed to be a "witness mark" for future reference.
    3) If you find the die dull after 50,000 cycles you may want to use A-2 over 0-1 (I'm not serious here)
    It looks fine enough but like the others have stated, coat the handles for comfortable use. I presume there's already slug clearance so you don't get stacking?
    1. Gasket Cutting
      By tpmx57 in forum Printing, Scanners, Vinyl cutting and Plotters
      Last Post: 03-03-2012, 04:19 AM
    2. Need Help!- Gasket material for Vacuum Workholding
      By tminnig in forum General Metalwork Discussion
      Last Post: 03-30-2009, 10:04 AM
    3. EPDM foam cord gasket
      By ZigMan in forum DIY CNC Router Table Machines
      Last Post: 09-11-2008, 12:22 AM
    4. IH Gasket Repair help
      By mattinaustin in forum Industrial Hobbies (Support forum)
      Last Post: 07-26-2007, 09:40 PM
    5. gasket help
      By santiago lisboa in forum Digitizing and Laser Digitizing
      Last Post: 02-13-2007, 03:27 PM
