Diemaking / Diecutting
Page 1 of 7 1234 ... LastLast
Threads 1 to 20 of 126
Forum: Diemaking / Diecutting
Discuss Diemaking and Diecutting here.
  1. Shaped sheet metal punch
    Started by Jim27‎, 01-09-2018 08:31 AM
    01-14-2018, 03:38 AM Go to last post
  2. Machining accurate pockets and features
    Started by Jim27‎, 12-28-2017 11:45 PM
    cnc, cut, size, suggested, test
    12-31-2017, 11:40 AM Go to last post
  3. Making a radius punch and die
    Started by Jim27‎, 12-27-2016 12:18 AM
    4 Pages
    1 2 3 4
    12-23-2017, 11:43 PM Go to last post
  4. Dowel pins for punching small holes?
    Started by Jim27‎, 12-09-2017 11:19 AM
    dowel, holes, milling, pins, side
    12-20-2017, 09:17 PM Go to last post
  5. How is finish polishing on punch dies done?
    Started by Jim27‎, 11-23-2017 02:47 PM
    2 Pages
    1 2
    cnc, dies, finish, mill, smooth
    12-20-2017, 09:12 PM Go to last post
  6. Need Help!- Help/Advice for Compression Die Design
    Started by cycleback‎, 12-18-2017 02:47 PM
    12-18-2017, 02:47 PM Go to last post
  7. Advice on making a forming die to bend flanges on aluminum sheet?
    Started by Jim27‎, 11-22-2017 03:24 PM
    2 Pages
    1 2
    11-30-2017, 12:15 PM Go to last post
  8. die/punch alignment for kickpress and thin material
    Started by Jim27‎, 06-29-2016 08:51 AM
    alignment, back, channel, die, press
    11-22-2017, 03:12 PM Go to last post
    11-09-2017, 03:11 PM Go to last post
  9. Unhappy Somab unimab 500
    Started by nnnn‎, 02-07-2017 03:15 AM
    02-07-2017, 03:15 AM Go to last post
  10. Need Help!- Suggestions for making blanking die and punch for thin copper sheet
    Started by JetForMe‎, 07-03-2016 02:21 AM
    blank, cnc, die, punch, tabs
    07-05-2016, 10:16 PM Go to last post
  11. Milling 50 RC h13
    Started by Motorsports-X‎, 07-21-2015 01:05 PM
    cutter, cutting, h13, mastercam, milling
    02-19-2016, 02:56 AM Go to last post
  12. brass die making for leatherwork
    Started by tossik‎, 12-17-2015 05:53 PM
    02-10-2016, 11:05 PM Go to last post
  13. Need Help!- Small slots in D-2. How would you do it?
    Started by Houndogforever‎, 08-04-2015 02:18 AM
    d-2, micro, slot, slotting, tool
    08-04-2015, 02:18 AM Go to last post
  14. How can I make this ?
    Started by armin_bb‎, 04-28-2015 08:43 PM
    06-10-2015, 02:48 PM Go to last post
  15. Sanity Check - Can I use a brake to bend steel rule?
    Started by BrianAday‎, 06-06-2015 05:07 PM
    access, brake, foam, rule, steel
    06-10-2015, 01:32 AM Go to last post
  16. I can draw CAD files for you
    Started by armin_bb‎, 04-28-2015 08:49 PM
    cad, draw, guys, jpeg, pdf
    04-28-2015, 08:49 PM Go to last post
    03-27-2015, 07:59 PM Go to last post
  17. Tips for making simple steel rule dies
    Started by leathersmith‎, 02-07-2007 02:57 PM
    2 Pages
    1 2
    dies, doi, rule, simple, steel, step
    03-20-2015, 11:06 PM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 1 users browsing this forum. (0 members & 1 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
