Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > DeskCNC Controller Board
DeskCNC Controller Board Discuss DeskCNC Controller Boards and the software that controls it here.
Old 01-18-2005, 03:30 AM
rogerbureau is on a distinguished road
Arrow DeskCNC Controller/driver
I want to run 3 PowerMax 11 stepper motors with the DeskCNC 3 Axis Intelligent Stepper Motor Controller (35 VDC max 2.0A 8 Microsteps/Full Step
Step up at HALF stepping
The motors P22 NRXC-LNN-NS-00 are connected in bipolar
Specs are: 200 Full step/revolution, 2 phases.
Rated Current/Phase is 1.55 amp DC.
I use a 24 VAC power Supply with a with a built-in 2.0A Slow Blow Fuse.
PROBLEM: (Power down betweem each connection)
1- Power up DeskCNC recognize the Controller
2- Connect the X axis MOTOR and JOG it many time no problem
3- Connect the y axis MOTOR and JOG it many time no problem
4- Connect the Z axis MOTOR , at POWER UP the Controller LED was not ON and DESKCNC could not recognize the BOARD.
5- I check my POWER SUPPLY and there was only 10 VAC output.
blow the 2.0A Slow FUSE
Can I use a POWER SUPPLY with a higher CURRENT RATING with that Controller?
Thank you
rogerbureau
Gecko's and Deskcnc serial board Don C Gecko Drives 2 02-19-2010 11:07 AM
Deskcnc users, what CAM software are you using with this controller? Idle hands DeskCNC Controller Board 4 05-06-2006 02:00 PM
DeskCNC TP-100 Probe released imserv Product Announcements & Manufacturer News 7 03-11-2005 09:10 AM
2nd Generation DeskCNC servo driver released imserv Product Announcements & Manufacturer News 0 11-24-2004 07:22 PM
2nd generation DeskCNC controller now shipping imserv Product Announcements & Manufacturer News 13 10-01-2004 07:22 AM
