Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > DeskCNC Controller Board
DeskCNC Controller Board Discuss DeskCNC Controller Boards and the software that controls it here.
Old 01-16-2005, 08:47 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Home is not working
I click the home button and nothing happens, no matter what settings I use I can get the machine to home. Mind you that all worked before I upgraded the deskcnc software. Any ides?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 01-16-2005, 10:01 PM
trubleshtr is on a distinguished road
what if you wiped it all out and re-loaded the software? perhaps a file got corupted during the up-grade? or perhaps you have a conflict with the resources in your device manager?
menomana
Old 01-16-2005, 10:21 PM
ger21's Avatar
Did some of your home switch setting get reset?
Old 01-16-2005, 10:46 PM
drk drk is offline
drk is on a distinguished road
I had the same problem, its not your hardware . The newer versions ( last two) have the provisions for homing scripts . You need to go to the machine setup tab- homing scripts. there you give the command of G30 X1Y2Z3 where X1Y2Z3 are the offsets from home position for each axis.
Try using just the g30 to begin with.
Hope this helps
Old 01-16-2005, 11:10 PM
CNCadmin's Avatar
Site Owner
You have to use homing scripts?
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 01-16-2005, 11:13 PM
CNCadmin's Avatar
Site Owner
one thing I didn't do is overwrite any of my profiles.
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 01-17-2005, 12:05 AM
drk drk is offline
That is a different issue altogether. Your machine profile , it seems wouldnt contain any info on how to home. I had written to deskcnc and this is what i had been told.
Since I wasnt comfortable with doing scripts etc.. I still am using the older version on my machine until i can work things out with the script.
Limit and home switches EMC and Mach2? ESjaavik LinuxCNC (formerly EMC2) 4 09-29-2008 11:39 AM
How do you hook up limit and home switches? CNCadmin DeskCNC Controller Board 6 09-23-2007 04:34 PM
Dirction / Step lines! bigal TurboCNC 2 02-06-2005 02:51 PM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 02:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 07:11 AM
