Results 1 to 4 of 4
Thread: Deckcnc board
    Site Owner CNCadmin's Avatar
    Mar 2003
    Deckcnc board and homing switches
    I'm having a tough time trying to get this board to work, the home switches do not work under any circumstances. The only way to home the axis was to use the limits. The one thing about that is once it’s on a limit the axis will only move .001 at a time, which means it, takes a long to come off the switch.
    Is anyone using the new board does that one work?
    Thank You,
    Paul G
    Site Owner-Webmaster-
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Mar 2003
    The homing is set in the machine settings as there are several options. You can hone each axis independently or all at once. They should be NC switches for all at once.
    You can also use the lim switch for n/o switches, but they cannot all be homed at the same time.
    Limits should be N/C and wired through estp, not home.
    Fred Smith - IMService
    http://www.cadcamcadcam.com/hobby
    Mar 2003
    I did all that, the only way that worked was using the limit for home.
    Thank You,
    Paul G
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Mar 2003
    Found the real problem- Servo set-up help
    Thank You,
    Paul G
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
  1. New board help requested
    By pminmo in forum Open Source Controller Boards
    Last Post: 09-30-2008, 06:10 AM
  2. single sided A3977 board ( got files uploaded )
    By tekno in forum Open Source Controller Boards
    Last Post: 01-27-2007, 08:30 PM
  3. New and need your help Please (driver board)
    By Oldmanandhistoy in forum General Electronics Discussion
    Last Post: 06-12-2005, 05:48 PM
  4. Hypothetical 1 axis 3977 board
    Last Post: 04-14-2005, 04:41 PM
  5. Running a parrallel interface board
    By Don C in forum DeskCNC Controller Board
    Last Post: 12-31-2004, 05:45 PM
