| DeskCNC Controller Board Discuss DeskCNC Controller Boards and the software that controls it here. |
After many hours of trial and error do to no paper work here is how you do it. Limit switches- these are wired in series, you need a switch per axis wired to a ground and to the "limit" terminal. You can use this without using home switches BUT you can only home in the "homing Sequence using "zyx" or "zxy". How it works- when you hit the "home" button the machine will home one axis at a time, when the switch hit than the next axis will start and so on. You must have the "home using Lim" checked off in the "deskcnc setup tab. Home switches- These are wired in parallel with the ground wire. Very important you must have the "home using Lim" un-checked in the "deskcnc setup tab. On the Machine tab you can select "simultaneous" for homing sequence. The switch for this will be normally closed, so as the machine homes and hits thw switchs the board sees +5v and goes on to the next axis. The above maybe revised, I have to double check all my facts but this will help many that have no direction.
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| hi guys I have a limit switch with 3 wire +5V GND and out put, I connected the out put to pin10 in breakout board and set Mach3 X ais limit switch to 10, but the switch is not sending a signal to Mach3, I am not sure why. Any help highly appreciated pieresolanie@gmail.com |
Thanks for your reply I have another Omron mechanical home switch which has 3 connection NC, N0 and COM, I didn't really try that one because I don't have a diagram for it. Do you have an idea how to connect the NC, NO and COM to breakout board? Thanks Piere |
| You do NOT need to use NO(normally open), so hook one to the 5vdc and the other (NC normally closed) to the correct pin. As you stated pin 10, I am not sure on the board you are using where that would hook up. You should refer to a shcematic.
__________________ Hey check out my website...www.cravenoriginal.com Thanks Marc |
Hi pointcloud, I am just testing one mechanical switch with NO since it is NO, I connected the COM in switch to PIN 10 in Breakout board and GND to NO, now normally when the switch triggered it suppose to send a signal to breakout board, correct, the signal should be a low nothing happen no response from Mach3, or the switch is not sending a low. !!! |
| In Mach 3 (I have) the switch is NC (low active). I know you can configure it normally open, but most use normally closed so that they can daisy link limits. Check out this site: http://www.machsupport.com/forum/index.php These guys are the writters of mach. Ask and they can tell you a lot more than I. If you do not get an answer there I can do some looking Monday. I can not remember excatlly..
| Limit and home switches EMC and Mach2? | ESjaavik | LinuxCNC (formerly EMC2) | 4 | 09-29-2008 11:39 AM |
| Home and Limit Switches | itsme | General Electronics Discussion | 2 | 02-20-2005 08:16 AM |
| The relationship of limit switches to home switches. | MikeAber | General Electronics Discussion | 4 | 11-04-2004 02:28 PM |
| Limit switches and home switches | viktorcnc | TurboCNC | 2 | 08-03-2004 07:11 AM |
| Home switches and limit switches. | ynneb | General Electronics Discussion | 5 | 04-08-2004 06:32 PM |
