| DeskCNC Controller Board Discuss DeskCNC Controller Boards and the software that controls it here. |
Hi everyone I have a small road block that has set course to my route, maybe you can help to solve it. I found the perfect stepper motors for my setup but I can't seem to locate a circuit that will handle the amps. Here's the motors 4: NEMA 34 HIGH TORQUE STEPPER MOTOR 640 oz-in, Shaft with a flat, 80 mm KL34H280-45-4A (Single Shaft) Specification Price: $89 Rated Current: 4.5A, Rated Voltage: 4.1V http://www.kelinginc.net/SMotorstock.html I liked these but it needs a voltage of 500v ![]() http://www.circuitspecialists.com/prod.itml/icOid/8930 I wanted to use mach 3 as the cnc software any one know of any schematics that can handle my amps and can be used with mach 3? Any help would be greatly appreciated |
| I think you posted in the wrong forum but as far as the motors go you looked at the wrong specs. That 500v is not to power the motor but it is an insulation raring. Based on the spec sheet, this motor is happy up to ~100vdc. Kelingcnc has a bunch of different drivers, just check out there site.
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| Opps I knew it was either this one or the stepper motor driver one As for the Kelingcnc I wanted to build my own to cut costs down. I am a college student so money is not heavily on my plate to buy Assembled ones Thanks for your input And for the tip on the stepper motor from circuit specialist |
Any driver that accepts industry standard step and direction signals can be used with mach3 and be driven from the pport. Always use a breakout board. IMHO. Mike
and a stepper motor controller. One that can handle a NEMA 34 of course |
1 driver per motor is correct.
Ouch not much on the cost effective side If that is so then it would be a lot cheaper to build the stepper motor drivers myself I just need the schematic |
#10
| Chec this thread for why it will be a long road for drivers of that power output. power and controller help Not that it impossible, just a false economy if electronic design isn't your full time job. Not to mention that you get a waranty and customer support. If you have any further questions, pm me or start a new thread in the appropriate forum. Mike
| Need help to locate a strong stepper motor | Techbuilder | Stepper Motors and Drives | 5 | 10-02-2008 10:09 PM |
| Steper motor driver board needed | maydayy | CNCzone Club House | 3 | 12-22-2007 08:21 AM |
| Beltdrive-stepper motor-stepper motor driver | Georg | Stepper Motors and Drives | 0 | 10-16-2007 05:56 PM |
| 3 axis unipolar motor driver board | serkanozfe | Stepper Motors and Drives | 1 | 02-15-2005 02:28 AM |
| what voltage? i'm confused.. Stepper motors + driver board from hobbycnc | Loterus | Hobbycnc (Products) | 8 | 01-26-2005 08:10 AM |
