| DeskCNC Controller Board Discuss DeskCNC Controller Boards and the software that controls it here. |
Can anyone tell me if the serial DeskCNC 2nd generation board will work with Mach2? I am building the CADCut Router 4x8 and am beginning to look into what controller, software etc. Any suggestions of a good marriage would be helpfull. DeWayne Young (UK)
__________________ DeWayne |
| NO, it won't. It only works with the DeskCNC software.
Fred Smith - IMService http://www.cadcamcadcam.com |
I found the Adaptor - USB to RS232 Serial Adapter from cadcamcadcam homepage. At now I am using the compaq notebook, but I don't got the parallel port and just got USB port only. Did it really support the DeskCNC board and software. I would like to hearing yours help. Thank you very much. Last edited by weberluk; 09-23-2005 at 03:23 AM. Reason: double as same about post before and I would like to ask another question, please |
I am a beginner and would like to choose DeskCNC, but I don't know how to setting the router working area and Axis. Is it easy to setup or need some of program knowledge or like as same about used Mach2 type? I feel some of difficult at first. On the other hand, when I saw another controller forums, discovered too many problem from them. I am afraid I don't know anything from DIY CNC before. If poosible, can you help me? Because was the selling prices and software function very nice and I like it. I am looking forward to hearing for yours reply soon. Thak you. |
| The setup procedure is on-line: How to set up DeskCNC Fred Smith - IMService http://www.cadcamcadcam.com/hobby |
| I believe this is very usefully information as well as thank you very much. I forget ask one question? It's relate about power input from DeskCNC with Controller Card. Did it support 220 Voltage power or not need of used transformer? Because was Hong Kong used 220V. Thanks a lot. |
| A 12V plug pack into your 220V power sustem is all you need to run the controller board.
__________________ "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't" Greetings From Down Under Dave Drain Akela Australia Pty. Ltd. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
#10
| I just purchased a cnc router from moosecreeksales on ebay.( it'sitem number 320109204739 if you care to look at the listing), and the machine's maker suggest's using MACH3 software. However, I'm new to cnc (my only experience is with engravers and their software) and I got a copy of EASYCNC which suggest's DeskCNC as the best software for beginners. Even though it cost's about $100. more than Mach3, from the demo's it looks like DeskCNC is a lot more intuitive and less intimidating for me. My question is this: can I use DeskCNC with whatever kind of control board will be comming with my router, or am I going to be pulling my hair out trying to make it work. We all know that nothing boost's one's confidence like having some success in the begining of using new equipment. Any help or thoughts would be welcome, and I thank you in advance. PS-as an alternative, I would consider getting DeskCNC bundled with their board (and probably the USB adaptor) if it would get me up and running with better and easier results. Thanks! |
#11
| Mach3 sends step and direction signals through the parallel port, but DeskCNC sends the step/dir signals from their board, so it's required, and makes DeskCNC about $200 more than Mach3. There are also 2 very good Mach Support groups, and thousands of users that help out.
#12
Do you mean that Mach3 uses no controler board? If so, what do the steppers connect to? And does this mean that DeskCNC actually requires 2 boards, the controler my system comes with and additionally requires their own proprietary board? Pardon my ignorance, but I'm trying to get a handle on this stuff. Thanks! |
| Who can setup Xylotex XS4430U with Mach2? | minicnc | Xylotex | 2 | 08-01-2005 07:22 AM |
| Hooking up HobbyCNC board and motors to PC... | jdbaker | Hobbycnc (Products) | 7 | 06-06-2005 02:10 PM |
| Mill Post: MC9 to Mach2...I'm using a Xylotex Board? | EPM | Screen Layouts, Post Processors & Misc | 7 | 04-20-2005 10:05 PM |
| Mach2 & Rutex relay board. | ynneb | Mach Software (ArtSoft software) | 1 | 08-22-2004 02:50 PM |
| Hooking up the xylotex board | yukonho | Xylotex | 6 | 01-17-2004 12:30 AM |
