Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > DeskCNC Controller Board
DeskCNC Controller Board Discuss DeskCNC Controller Boards and the software that controls it here.
Old 08-30-2004, 12:19 AM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
4th axis controller board?
Is the 4 axis controller board available yet? Any info that anyone can share would be great.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 08-30-2004, 04:38 PM
Kookaburra's Avatar
Moderator
Kookaburra is on a distinguished road
Paul,
The controller that you were sent should control a 4th axis, you may only need a stepper or servo driver to use the facility, check on the deskcnc board to see if you have an "A: step and direction, if so all you will need is a device to drive you motor. Let me know and I will try to help you out.
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
Greetings From Down Under
Dave Drain
Akela Australia Pty. Ltd.
4020 4th axis problems little bubba Fadal 3 06-13-2005 10:08 PM
3 axis stepper motor controller board - question Yellowbeard Stepper Motors and Drives 17 04-06-2005 11:02 PM
HobbyCNC 3 axis controller board review CNCadmin Hobbycnc (Products) 32 02-10-2005 05:43 PM
want to add 4th axis to stepperworld fet3 board gv71 General Electronics Discussion 5 05-29-2004 12:10 PM
