| DeskCNC Controller Board Discuss DeskCNC Controller Boards and the software that controls it here. |
#13
| Just try opening it with notepad, as it is most likely a text file.
#14
| I assume this is a manual tool change ?: Edit your G and M code in notepad. In the move before the needed tool change raise the Z to appropriate height. Then create a pause ( GO4 P , P representing the time needed for the pause ) NOTE for saftey sake hit the pause button on the screen also) Change the tool, then go to the top header on the screen and hit the "controller " button, then "change tool ( broken tool )" button, and follow the instructions. My advice is to go through the procedure a couple of times...After a little practice, you should be able to change the tool in less than 30 seconds. Adobe (old as dirt) |
| G Code Change | gm3211 | Haas Mills | 4 | 09-20-2007 07:02 PM |
| How to change Tool change position(About MAZATROL T1 control) | liushuixingyun | Mazak, Mitsubishi, Mazatrol | 5 | 07-07-2007 02:58 PM |
| tool change | jrick | Commercial CNC Wood Routers | 0 | 01-13-2007 05:01 PM |
| Tool change | lilricky2 | BobCad-Cam | 2 | 06-03-2006 01:00 PM |
| Tool Change | WOODKNACK | General CAM Discussion | 10 | 07-12-2003 09:26 PM |
