Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > DeskCNC Controller Board
DeskCNC Controller Board Discuss DeskCNC Controller Boards and the software that controls it here.
Old 12-06-2007, 09:50 PM
bradyfb is on a distinguished road
Unhappy ANYONE HAD SUCCESS WITH VECTORART3D FREE DNLOADS
I downloaded the free 3D files at vectorart3D, I cut them and they look nothing like others i have seen at vectorart3D. I need help!!! James Booth emailed me and told me to try a 1/8" and 1/16" ball nose, I got them; and try a stepover of 10% of the tool dia. and I'am useing oak wood and I'am also scaleing it down to 3"X3" inches
Under stl machining:
Blank i mark male,
rough pass is 1/8" with a .110 stepover
roughing para; rough dir I go against the grain of the wood how much stock should i be leaving for the rough pass?
stock to leave is .032
Finishing toll is the 1/16" ball nose
with a stepover of .055
finishing pass what should the stepover be XYZ on rough and finish and stock to leave?
and when doing thes files deskcnc gives a M06 command where it changes to the finishing pass, this is where i would hit the pause button so i can change bits. only my machine keeps running does not stop at M06 is there another command I should be useing? Also could i be doing this with just a finish pass or useing the 1/16" bit for both passes? Thanks Brady
Old 12-06-2007, 10:17 PM
ger21's Avatar
If you use 10% of the tool dia for the stepover, your finish pass stepover should be about .006, not .055.
If you try to skip the roughing and finish with a 1/16" tool, there's a good chance you'll break it.
Sketchup success in CNC? ZipSnipe General CAM Discussion 10 02-27-2011 10:59 AM
Success HX6090SE pedroman Laser Engraving & Cutting Machines 1 05-25-2007 09:02 PM
IMTS 2006...A Success! CNCdude BobCad-Cam 3 09-20-2006 04:22 PM
R2E3 success story bkraz Bridgeport and Hardinge Mills 3 12-02-2005 02:34 PM
At Last, Success is Mine! jstuedle CNCzone Club House 4 07-06-2004 10:26 PM
