| DeskCNC Controller Board Discuss DeskCNC Controller Boards and the software that controls it here. |
| Hi, I am at the early steps in CNC and i have some questions maybe stupid,maybe good to mention.But the point is that i don't know the answers.Because i have many questions,i will post them with order and clarity.If anyone has the courage to answer them i will be more that grateful. 1)Backlash compensation works also for jogging? 2)What is the "Meter in backlash" under the tab Machine setup/Machine.Is it true that it works when you cut circles? 3)What is "Buffer output"? 4)Can someone explain to me with an example the role of the Tolerances tab? what is Min arc length,Min Arc radius and Tan deviance?And what are the effects/result when you change them?(I think by bringing an example something like based on a DXF design,will be better for me)! 5)What is "Read absolut Arc centers"? 6)And finally,what is "Break arc into lines" Sorry if i don't understand technical words but i live in Greece and its difficult to know all these words(and their meaning of course!) If anyone out there... Thanks in Advance! Panos |
| This is not a DeskCNC support forum, it's a public discussion area. If you are a registered DeskCNC user, you should contact your dealer with these questions. If you do not get satisfaction from your dealer, contact DeskCNC support by e-mail. If you use a search engine, you will also find that I (and others) have previously answered most of these questions in public discussion forums. Fred Smith - IMService http://www.imsrv.com |
| I have DeskCNC, and will be moving to Mach soon due to my unhappiness with DeskCNC. 1)Backlash compensation works also for jogging? Yes. You can verify this by ear as well as with an indicator. You need to do this to verify your backlash compensation anyways. 2)What is the "Meter in backlash" under the tab Machine setup/Machine.Is it true that it works when you cut circles? I think so. 3)What is "Buffer output"? I assume this has to do with sending directions to the controller board. Dunno. 4)Can someone explain to me with an example the role of the Tolerances tab? what is Min arc length,Min Arc radius and Tan deviance?And what are the effects/result when you change them?(I think by bringing an example something like based on a DXF design,will be better for me)! I have had issues with creating toolpaths on small arcs. Messing with these values seemed to help. 5)What is "Read absolut Arc centers"? Dunno. Haven't messed with it. 6)And finally,what is "Break arc into lines" Dunno. WATCH out for the fact that the FEED override changes the JOG override as well... an easy way to stall out your steppers. -Jeff |
| Before you throw out the baby with the bathwater, your issues (with the exception of backlash comp) appear to be CAM related. The tolerances you listed would be how the software converts a DXF file into g-code and how it treats lots of small arc segments and lines, and that is not actually part of twisting the motors (control). If DeskCAM will let you import/run g-code, then you can use an external CAM program that might be easier to understand and get usable toolpaths. SheetCAM is a low cost CAM for 2D and 2.5D toolpaths and has features (auto tool offset, auto lead-in's, tabs, etc) and it's DXF import does a pretty good job of building continuous node chains. There are tolerances in the setup but seldom need to be messed with once setup. As for backlash compensation: It's not easy to do in any package. In the long run the better approach is to engineer out the backlash in your machine. MACH has backlash compensation but you have to turn off one of the features that makes it a nice controller: CV (Constant Velocity) that gives smooth moves and cuts. Art is working on making backlash comp better but after almost 5 years of MACH development it's clear it's a big challenge. I don't know what you are using to draw with, but if the artwork gets exported with lots of segments then the import needs to do some "blending". It's aways a tradeoff between accuracy and smoothness. Opening up the tolerance will make things smoother but the deviation from the actual drawing will be greater. If it's decorative in nature it won't matter. If it's a close tolerance machine part it will. This may sound like I am discouraging you from MACH. Far from it. I have been using it from the very first and virtually every product we sell is based on it. I have hundreds of hours if MACH sticktime. You just need to be aware that for the issues you listed it is not going to be a magic bullet (except maybe for support from lots of end users). You will have to abandon the pulse card that mates with DeskCNC and count on using another CAM program to develop toolpaths. MACH has LazyCAM but it's more a import filter than a true CAM program. I can understand your frustration but I don't want you to think you can switch systems and all the problems will go away. Part of it may be the drawing tools you are using (?) and settings in the import and conversion engine. If you can use DeskCAM to control your motion and other tools to do the toolpath side you might have a compromise that won't require a total retro fit. On the other hand if you do want to come across to the MACH side you will get lots of support and there is a huge amount of products and goodies built around MACH. Tom Caudle www.CandCNC.com |
| Mr Smith,sorry for beeing that hursh about DeskCNC support,but indeed even when i used the search engine didnt seem to find an answer that satisfies me.I have purchased DeskCNC from Carken inc. so i think that makes me a registered user,i don't know Anyway, i don't have a problem with anyone, but some times i get frustrated not knowing things and don't find answers.Most of my questions are answered,directly or indirectly,by the guys here(thanks fellas!!!)I think trial and error will be the only solution when you need to understand something in deep.I don't have a particular problem with DeskCNC because i haven't used it yet(im in the conversion stage with my mill)so i don't know its limitations.But i will take a look at mach3,SheetCAM etc. Thanks a lot for the support in any kind! Panos |
#10
| Hi There Fred, Yes, this is not the DeskCNC forum, but if I go to the IM Services Forum, for DeskCNC boards, there has been no answer from you, or anything posted since last year. I have posted questions, but they are all in the "Moderator Checking" mode, nothinh has made it to the forum posts !!! How and where do we ask questions, if we are registered users of your software and boards, I have 2 sets !!! Where do we do it, and at least receive a reply, anything to know you have moderated it, or have the post placed on the web, for users to reply to my questions. Remember, you are experienced, have the knowledge, know the terminology. For you, serching the forums for answers is easy, but for us Newbies, who fell for your marketing, and bought your products, we struggle. So, your comment that, "search for your answer" sucks. Remember, many years ago, you were like us, 10 toes on each hand. Now we want to be like you, we want to learn, but don't "not reply" to us !!! At least lead by example, and direct us to a post, if you know it is out there. My 10 cents worth !! Regards all, Francois Where, where, where, where ???????????????????????? |
#11
Hi, I received an email From Fred Smith: "The public DeskCNC support forum is now closed. If you are an IMService customer, you may still be eligible to receive support through e-mail or our private DeskCNC forum. To request support by e-mail, please include your name, what and when you purchased, and enough identification to make it possible to identify you as our customer. Fred Smith - IMService" So as you can see my friend you re almost alone. I think that you still can post some questions here in CNC zone. Some times you have to "press" for answers to come(i was in that position a long time ago,when i needed certain answers to move along,but the answer was not there).I know that some people know the answer to your question,but they re bored to answer.Its logical some times,because when you post a simple question that for someone is simple but for you is a "mountain" he is thinking that its a waste of time to write a few lines,because you may come up with a new question,and another one,and a new one and so on... As you can see im also a newbie and a Chip sweper.But some times its better to experiment yourself than looking for ready answers.That makes you more smart!!! Friendly, Panos Labrakis Greece |
#12
| Hi There Kolokitas, Yes, you are right, I also received that mail from Fred. They mention, "... still reply via the private forum, please identify yourself...." I did just that, sent a fax to their office, mentioned the invoices to 3 boards I have, all purchased less than a year ago. Asked them to inform me of the private forum. But ALAS, STILL NO REPLY !!! SO, FRED, IF YOU ARE OUT THERE, YOU LEAVE ME NO OPTION TO NOW BE OF OPINION, YOUR BOARD SEEMS FINE, BUT YOUR SUPPORT SUCKS !!! And I'll now openly advertise your lack of support, rather than recommend your product. I've really tried hard, but absolutely no reply, that's unfair !!!! Regards, Francois |
| Scary Stuff | ToyMaker | Safety Zone | 286 | 12-30-2011 09:00 PM |
| Mach3 tuning (cuts small stuff fine, but is off on big stuff) | jdbaker | Mach Software (ArtSoft software) | 4 | 03-15-2007 12:30 PM |
| Need someone to help me understand this stuff. | tersmurf | Mentors & Apprentice Locator | 3 | 01-05-2007 10:19 PM |
| Want to see how those who buy some of you stuff play? | weimedog | CNCzone Club House | 1 | 08-28-2006 07:54 PM |
| welding thick stuff to thin stuff - need advice | cross6 | Welding, Brazing, Soldering, Sealing | 5 | 01-13-2005 02:39 AM |
