I have switched from gibbs to bobcad and cannot get the desk cnc to cut a circle. I am trying to create a pocket. I have tried several sizes of pockets and cutters ang get the same message every time I try to use the g code in desk cnc. " current point same as end point of arc" I get this code on line N07
I do not know how to put the drawing file up here bit it is a circular pocket .080 deep that is .160 dia. and the cutter is .032. I did create a contour for the circle and used it to create the toolpath. Anyone know what Is going wrong to cause this? Thanks Chris
(; PROGRAM NUMBER)
(; PROGRAM NAME - .032 PKT.NC)
(; POST - DESKCNC MILL)
(; DATE - SUN. 02/12/2012)
(; TIME - 09:13PM)
N01 G90
(;JOB 1 POCKET)
(;FEATURE POCKET)
N02 S5998 M03
N03 G00 G90 X.0004 Y0.
N04 M08
N05 Z.1
N06 G01 Z-.08 F14.3974
N07 G03 X.0004 Y0. R.0004 F23.9957
N08 G00 Z.1
N09 M05
(; END OF PROGRAM)
N10 M02
Hi Chris,
Just looking at the code . . . . .032 + .0008 and you get a pocket .0328
I doubt you would even be able to see the table move that little bit of movement.
I would check to see if BobCad is set in MM mode
Check my math, I think the R value should be more like
.072, I don't know what you are cutting but giving the diameter of that cutter F23.9957 seems a bit fast too, esp. at .080 deep.
I doubt you can cut anywhere near that deep without breaking the cutter as that is 2 & 1/2 times it's diameter. If it didn't break
it would very likely make a cone shaped hole.
Bob Cad's default feeds seem way fast for most of my applications.
We're not in business to make parts, we're in business to make money, making parts is just how we do that.
