spectralight retrofit
Results 1 to 2 of 2
Thread: spectralight retrofit
    Apr 2006
    Default spectralight retrofit
    I need some help on the wire color codes of the steppers and limit switches.I seen that other people have redone theres and i would like to see there wiring diagram.Im using the same power supply and motors.any help would be appreciated thanks.
    Apr 2006
    Default Re: spectralight retrofit fixed
    I figured out the wiring on the 3 axis,it wasnt to bad .I used a tb6600 all in 1 controller and it work awesome ,I also added a forth axis.If anyone need the wiring pm me and i will get it to you.
