- New Machine Build- Board controller
Board controller
Re: Board controller
Hi
since both kits use the same 24V supply
out of the 2 kits -
the CNC kit Nema23 stepper motor 3axis (23HS6430 +DM542)+350W24V+breakout board
is the kit I'd choose
1st the stepper motors have a lower inductance and should run faster
2nd if you damage a stepper driver the DM542 driver is easier to replace than the IC's on the all in one board
the TB6560 Control Board has a habbit of self destructing
see
http://www.cnczone.com/forums/genera...r-updated.html
John
- You may not post replies
- You may not edit your posts
Forum Rules
