Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > DesignCAD and ContourCAM
DesignCAD and ContourCAM Discuss DesignCAD and ContourCAM software here.
Old 01-13-2008, 02:45 AM
magic is on a distinguished road
ContourCAM and Windows Vista
Hi again,
We thought, we had a problem, when we tried out ContourCAM with DesignCAD 3D MAX ver. 18 on Windows Vista, but it turns out that there is a solution.
In the ContouCAM Configuration under Setup=>General.. change the DesignCAD 3D path to c:\Progra~1\IMSIde~1\Design~1, then the integration will work.
Another thing is that we use an older version of Help, and Microsoft has decided that this does not come with Windows Vista, so you will get a message saying that you have to fetch the WinHlp32.exe yourself.
You just need to follow the instructions, or find it here http://www.microsoft.com/downloads/d...0-334cd175d4bb
Old 02-03-2010, 02:07 AM
joyasmith is on a distinguished road
Re:ContourCAM and windows vista
Well…..ContourCAM and design card are working with Design CAD 3D MAX ver. 18 with Windows Vista. because DesignCAD creates the folders that ContourCAM easily can installs into at the first run. So If you are working With ContourCAM with windows Vista then you have to be working with Design 3D MAX ver.18……..by using this version I don’t think so that you face any kind of problem.
ZWCAD
CAD Design
Mastercam and Windows Vista Chuck Reamer Mastercam 17 10-28-2007 02:42 AM
Windows Vista Please help SWPM Surfcam 5 10-06-2007 09:53 AM
Dolphin & Windows Vista TZ250 Dolphin CADCAM 5 06-07-2007 11:41 AM
Windows Vista SWPM Solidworks 1 05-01-2007 11:35 AM
Here it comes...Windows Vista... fatal-exception Mach Mill 2 02-08-2007 10:56 PM
