I picked up a 90 Maho MH600c last week and its all up an running. Its got a 432 with 6601.601 software rev. Did all the usual maho crap, loaded new constants, new battery. I really dont want to have to reenter the constants by hand and Ill be using this with cam so I need a serial connection. Right now Im just trying to send my constants out to a laptop.
Using predator and 4800 N 7 and 1. I have a 3 wire cable. 25 pin to 9 pin : 2 to 2, 3 to 3, and 7 to 5. This does nothing on any flow control setting. A hayes modem cable gets tons of flow errors, transmits a bunch of junk. Same result with a standard null modem cable. I have parameter 770 @ 2, 771 @ 0, 772@ 1, 773 @ 2, 774 @ 30, 775 @ 1, 776 @ 9600. I also tried using a smart cable serial analyzer. I could either get garbage out or nothing on any of the settings. This leads me to believe I need a very specific cable and/or my constants are not correct.
I have the original cable the previous user was using but it does not connect at all either. I didnt check the 25 pin end of that cable, but its different on the 9 pin end than the 3 wire one I made. It also was routed through the operator panel support arm so I cant see all of it to check for damage or ring it out without removing the panel covers. Anyone with serial experience for this? Thx
Got transfer! Those interested in seeing how this is done can check: http://www.cnczone.com/vb...le-196540.html
