Yes you can do both, but also depends on material. They have other machines that do this work just as well.
Hi
Could any body tell me if we could buy dmu 50 evolution machine in case we are planning for impeller machining and blisk machining.
Hi
Material is going to be Titanium
Titanium will not be a problem. If you are ordering make sure of scales in xyz, probe and laser tool setter for best accuracies. Machine comes standard with 18,000 RPM spindle, it has a high tourque rating and plenty of HP. HSK 63 tooling is a must at the higher RPM, althought a bit more expensive, it is a better balanced holder than CT or BT.. GOOD LUCK
