Results 1 to 3 of 3
Thread: Drip feed with MAHO 600E-Phillips cnc432
    Dec 2008
    Sweden
    I have test the drip feed (BTR) function on our MAHO 600E, but i did not success with it? This is how i do it, i press "Menu" & "1 Blocksearch" & hit the softkey "BTR OFF" and then "Prog mem" & "Data input" and softkey "Input".
    And then i start to transfer the NCfile from the PC, and i use a standard program who starts with:
    %PM
    N9001 (For example)
    N1 G52
    N2
    N3
    N4
    N5
    I go to "Auto" & then i press "Start", and the machine start the milling at the same time as it recieve data from the PC. And it works well until 3200 "N"blocks has been transferd, and then i got errorcode "D07"(Program memory full". I have set the MC(Machine constant) N93 to 1024 Byte.
    I don´t now if i have to do something more, or if the NCprogram have to start with another character then "PM"?
    I use Edgecam to transfer the NCfiles to Maho
    Dec 2008
    Sweden
    Now it works fine, i have to change the ncfile so it look like this:
    !%PMN9001
    N9001
    N1
    N2
    N3
    Registered smoregrava's Avatar
    Sep 2005
    Norway
    Hi Is it possible to have a copy of your parameters. I'm going to uppgrade my Maho 432 controll to a later model. and will then be able to dripfeed I hope. But I belive I need to set the parameters rigth to do this so it would be nice to know the parameters that needs to be set to Drip feed.
    What program do you use to transfere the code from the computer?Mayde it's possible to do it with Hyperterminal
    Do you know the versjon of you 432 controll?
  1. Maho Phillips 432 manuals?
    By HKgunslinger in forum General Metal Working Machines
    Last Post: 08-31-2012, 01:09 AM
  2. Need Help!- Maho MH600E - CNC432 Data transfer problems
    By Grusse in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-18-2009, 02:29 PM
  3. Maho MH 800E (CNC 432 Phillips)
    By kotten1 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-28-2008, 04:54 PM
  4. Maho 400E or 600E
    By HKgunslinger in forum Want To Buy...Need help!
    Last Post: 11-09-2008, 08:12 PM
  5. Maho Mh 1000c C/w Phillips 432-20
    By SIMONB in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 07-06-2008, 05:13 AM
