Results 1 to 5 of 5
Thread: Maho MH600E/Philips 432 toolchanger
    Aug 2009
    Czech
    We install this machine and setup constant form some list.
    Does not works automatic toolchanger. Still error 185 "Tool in tool changer gripper".
    Where can be problem ? Must be some calibrated or set some constant ? Or is some dammaged ?
    Aug 2009
    Czech
    Solved.
    1) save data via RS232 from MH600E to notebook
    2) unplug batery for cca 1minute
    3) plug batery
    4) set manualy RS232 constants
    5) load saved data via RS232 to MH600E
    Aug 2009
    Czech
    Next problem - changing of tools works, but some suspicious.
    F.eg:
    are presented Tool 7 and Tool 13.
    1) is used Tool 7. Then is used Tool 13. But changer place Tool 7 back into position of Tool 13 and not into position of Tool 13. Why ?
    Does exist some manual, how must be set Tools constants ?
    Dec 2006
    This is how this toolchanger works-- random access. If you look at the tool table there is a 'P' or position number for each tool. This is the position in the carosel that the tool occupies. The machine keeps track of where it takes tools from and where it puts them back- it will update the P value. The tool number does not have to correspond to the position in the carosel.
    Oct 2009
    Mexico
    Maho parameters
    I just bought a 1989 Maho MH600E, the batteries went down and all parameters are lost. Could you share the parameter list with me?
    1. PHILIPS 432 (MAHO MC50)
      By abbas in forum Deckel, Maho, Aciera, Abene Mills
      Last Post: 10-24-2009, 05:17 AM
    2. Need Help!- Maho MH600E - CNC432 Data transfer problems
      By Grusse in forum Deckel, Maho, Aciera, Abene Mills
      Last Post: 09-18-2009, 02:29 PM
    3. MAHO-PHILIPS 432 M60 and G23 problem
      By micktat in forum Deckel, Maho, Aciera, Abene Mills
      Last Post: 03-03-2009, 05:10 PM
    4. Maho MH600E Milling machine questions???
      By marx911 in forum General Metal Working Machines
      Last Post: 01-23-2009, 01:51 PM
    5. Maho 650 - CNC 532 Philips
      By nylas in forum Deckel, Maho, Aciera, Abene Mills
      Last Post: 01-13-2007, 01:41 PM
