Results 1 to 2 of 2
Thread: Need Help with Maho MH700 S, serious faults!
    Feb 2009
    NORGE
    I`m troubleshooting on the -88 mod Maho mh700s with grundig steering.
    Problem is that the power supply to the drives doesn`t get any power, the contactor that delivers wont get in.
    If I force the conactor the fuse for the DC intermediate course goes out!
    Also during start up of the system, all drives passes the test, but one that says "FAILED"
    The faults I`m getting are:
    I01: Interface not on power
    M01: Checksum error constant memory (RAM-memory)
    Please help and quick
    Dec 2008
    Sweden
    M01: Checksum error, means that any machine constant has been changed from the last time the machine running. If you have change any MC, be sure that you have switched back the MC switch when the machine is on power! If you change MC and then switch off the main power when you still are in the MC meny, and then the MC switch you will got the error code M01. IŽll hope you got what i mean?
  1. Need Help!- Problem with Maho Mh700 Y axis
    By mlautier in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 05-04-2011, 09:24 AM
  2. TM1 faults
    By f1jdm in forum Haas Mills
    Last Post: 01-10-2008, 06:22 PM
  3. Faults limit switch
    By TT350 in forum Tormach Personal CNC Mill
    Last Post: 09-25-2007, 12:51 AM
  4. Servo faults are showing up again
    By bgolash in forum Servo Motors and Drives
    Last Post: 04-29-2007, 12:07 PM
  5. Servo Amp Faults
    By Karl_T in forum Servo Motors and Drives
    Last Post: 04-04-2007, 10:48 PM
