Hai Atul,
There is from motor Z,that's same problem with my machine also.
My DMC 63V Z axis drops to the machanical end positon when I hit the enclosure door open switch. Due to which ballscrew bearing clamping bolts shear off or the belt which drives the ballscrew breaks. While running the program this malfunction not observed. It observed when I hit the enclosure door open switch or internal stop switch. It seems that after hitting those switches the motor fourcefully drives the Z axis to the end limit. Power cables and encoder cables are OK. Is the problem is with motor or the drive? Please suggest.
Thanks...
Atul
Hai Atul,
You must call to DMG india (Mori seiki). if your machine is from Famot, is necessary to do a retrofit electrical.
Unfortunately, Its more than 2 Jears ago, until I could answer. Its not a problem of the Motor. The Z-Axis Motor have a magnetbrake. If you close the door, the brake is lifted before the motor get current. That happens, because Deckel have some wrong Circuits in the Control. They know it, but don't say it to their customers.
Dear Concern Person,
We have a machine name is DECKEL MAHO DMC 63V
TNC 426/430
HEIDENHAIN
NC: SOFTWARE
280475 16
The problem is that our machine hard disk is dead and not working due to media card problem also our backup is crash and not repairable. We need software in above mentioned machine so that we can buy other hard drive and install it so that our machine will work smoothly.
Your prompt reply is required in this regard.
My email address is: gulzar.adnan@gmail.com
Thanks,
Adnan Gulzar
