Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills
Deckel, Maho, Aciera, Abene Mills Discuss European "Deckel type" mills. Abene here!
Old 10-10-2008, 10:45 PM
moldxman is on a distinguished road
maho toolchanger help needed
I have a Maho MH600 E2 mill.
I was in the process of changing tools with the toolchanger when the power went out in the shop .
How do you reset ?
Jim
Old 10-15-2008, 12:24 PM
suckerdave is on a distinguished road
I have a DMU-80 and on that machine you can either do a m77 from the MDI page which resets the toolchanger or you have to physically move the changer arm thru the positions to reset the machine form the control page.
Hope that helps.
Old 10-15-2008, 03:11 PM
sneebot is on a distinguished road
There are a couple ways to do this. Not sure of the m77 works or not with that vintage. Under the toolchanger are all of the hydraulic vavles which can be activated manually- this will allow you to move the arm and door around seperate from the actual control. If you need to get the control/ machine up and running before you do this it is possible to change around the machine constants so it thinks there is no TC and then change back when you've got everything back to normal.
What year is your machine and where are you located?
Needed Manual for Deckel Maho 63V vijayraghav22 Deckel, Maho, Aciera, Abene Mills 15 08-10-2011 12:43 AM
Maho MH800 E2, Machine Constants needed ffaspector Deckel, Maho, Aciera, Abene Mills 7 05-11-2011 07:40 PM
cnc DIY toolchanger??? marcerasmus CNC Tooling 1 10-07-2007 04:30 PM
Advice needed about maho 700 from 1978 Jeroenvanderloo Deckel, Maho, Aciera, Abene Mills 5 05-03-2006 11:45 AM
