Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills
Deckel, Maho, Aciera, Abene Mills Discuss European "Deckel type" mills. Abene here!
Old 03-25-2008, 05:44 AM
breazr is on a distinguished road
Maho 700 graphic simulation
Hello,
I have also problems using the graphic simulation on Maho 700 with CNC 432 Philips.
In fact, I'm not sure if this CNC controller has this cappability.
Did anybody use it ? And if yes, has anybody a scanned version of the graphic simulation manual ?
Thank you in advance,
Radu
Old 03-26-2008, 08:45 PM
thebodger@roger is on a distinguished road
If I can remember, you must add some code and parameters into the actual part program for this to work. I think, codes to define graphic "widow" size, and some other parameters. Best thing to find is an old MAHO CNC 432 training manual. It was one of the best and easiest CNC manuals I have ever seen. I know we have one in our shop. If I can find it I will make it into a PDF.
Old 03-27-2008, 04:42 AM
Hello thebodger@roger,
Thanks for your reply.
If possible, a pdf of the manual (or the chapter with graphic simulation) will be very helpful.
Radu
Old 03-31-2008, 01:41 PM
Here are some PDF files from the training manual. It should be easy to follow
Any Graphic Artists out there? zcases Employment Opportunity 5 10-19-2007 09:48 PM
Graphic display 10T guhl Fanuc 13 10-18-2007 09:39 AM
Graphic Work lal19541 Alibre Design 3 04-05-2007 03:30 PM
G Code to Graphic AJFab G-Code Programing 8 06-01-2006 08:20 PM
Fanuc graphic SAWMAN Fanuc 1 04-25-2005 11:38 AM
