Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills
Deckel, Maho, Aciera, Abene Mills Discuss European "Deckel type" mills. Abene here!
Old 03-25-2008, 05:39 AM
breazr is on a distinguished road
Maho 700 serial communication
Hello,
I have to communicate with a Maho 700 with CNC 432 Philips using RS 232 serial communication.
I have used the parameters and cable from Cadem web site and also their NClite software (which I used successfully with other machines), but it didn't work at all.
Does anybody run into the same problem and solved it (cable, parameters, commands) ?
Thank you in advance
Radu
Old 04-24-2008, 08:41 AM
sonnybiker is on a distinguished road
are u sure that u plug the cable to the rite com port? does the port is still function? does the parameter u enter to the interface and the coputer is the rite parameter?
Old 07-05-2008, 06:28 AM
kotten1 is on a distinguished road
Originally Posted by breazr View Post
Hello,
Radu
Hallo!
I have the same problem with a MAHO 800 CNC 432 Philips.
Have you fix the problem now?
Maybe you can help me please?
kotten1
/Sweden
Old 07-16-2008, 03:19 AM
smoregrava's Avatar
smoregrava is on a distinguished road
Hi folks. I just ran into this thread now. a coulple of days ago I manage to make my Maho mh500C to talk to my computer I wrote a post about that in the "grapical help please maho 432" thread here at CNC zone I write it again here so you guys also could connect your equipment.
Here is what I wrote:
Yesterday my Maho 432 to talked to my computer(DNC)for the first time. I have made a DB9 to DB25 full handshake cable (Like in the picture). And i used Hypertermial to transfere the programs. easy and seems to work nice
Here is how I did it if anyone wants to know:
First I checked Machine constants
Nr 115 =1 means 2 as stop bit (=0 means 1 is stop bit)
Nr 116 Input Baudrate and
Nr 117 output baudrate. In my case baudrate was set to 300, but I found in some papers that they had used 4800 before on my machine so I will change this as soon as possible.
Then I opened Hyperterminal (Is in windows under comunication)
I used this parameters
connect to Com1
Baudrate= 300
Data bits= 7
Parity= Equal
stop bits= 2
Flow controll Hardware
Send CR at line end
Local ecco
Then I go to the controll and press
"MANUAL"
"PART PROG"
I selected ALL MEMORY
press "MEM LOCK"
"DATA INPUT"
Then I used a simple program as a test
% PM
N9008
N1 G1 X20 F500
N2 G1 Y20
N3 M30
I marked the text/program above and rigth click in Hyper terminal window and choose "Paste to Host"
When all lines was sent I have to press
"CTRL+D" on the computer. Then the program is in the controll.
I Actually don't anderstand why I have to press ctrl+D. But is works
I also loaded programs and tool table out of the machine to the computer.
Old 09-08-2008, 01:59 PM
Jaswin is on a distinguished road
we are using rs232 port for philips 432 regualry.
we transfer long programs upto 8000 lines. we use NClink software which is freeware on net. only need is windowsNT on the computer as 432 is a old platform. if u need help let me know i can mail setting and port wiring diagrams. jaswin_sehra@hotmail.com
Need Help!- Maho MH 600 P CNC Metal Deckel, Maho, Aciera, Abene Mills 1 01-30-2008 08:41 PM
Maho 800 E communication question gv71 Deckel, Maho, Aciera, Abene Mills 0 01-11-2007 10:32 AM
serial port communication for a V2XT k.mccue Bridgeport and Hardinge Mills 2 01-25-2006 01:24 AM
Serial vs. parallel communication OCNC General Electronics Discussion 15 10-20-2004 06:53 PM
