Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills
Deckel, Maho, Aciera, Abene Mills Discuss European "Deckel type" mills. Abene here!
Old 11-02-2007, 10:34 AM
deckeldoctor's Avatar
deckeldoctor is on a distinguished road
Deckels with Heidenhain 410 Controls
Hello Guys,
Here are links to the Heidenhain 410 brochures and program manuals.
Please have a look in the classified adds for the 2 Deckels
I have for sale.
http://www.heidenhain.de/wcmsmimefil...1_27_15195.pdf
http://filebase.heidenhain.de/doku/t...345_940-22.pdf
http://filebase.heidenhain.de/doku/t...309_740-25.pdf
Regards
DD
Old 11-05-2007, 12:48 PM
Hello Guys,
Here are travel envelopes.
FP2NC X 11.875 (300) Y 15.75 (400) Z 15.750 (400)
Machine weight est with cabinet and flat table 3,420LBS
Machine requires floor space of 8.2 x 10.1FT with saftey range incuded.
This machine will be on 2 skids power cabinet on 4ft x 4ft x 4ft 600LBS and machine 7ft wide x 5ft long x 6ft tall 2830lbs
Electrical requirement total connected load 12.5 KVA
FLOOR LOADING 720LBS/SQ FT
FP3NC
X 15.75 (400) Y 15.75 (400) Z 15.750 (400)
Weight 4,220 LBS
Machine requires floor space of 10.8 x 8.2 FT with saftey range incuded.
This machine will be on 2 skids power cabinet on 4ft x 4ft x 5ft 650LBS and machine 7ft wide x 5ft long x 6ft tall 3570lbs
Electrical requirement total connected load 14.5 KVA
On the above machines I was able to tweak a little more travel out of both machines due to using software travel limits and keeping the limit switches active for extreme over travel and estop.
The above machines are actually alittle lighter than I stated above because 23 circuit boards are gone and the old heavy operators console is replaced with aluminum operators console with no circuit boards in it.
Old 11-05-2007, 12:49 PM
Hello Guys,
One other note I would like you to know I am trying to sell these machines quickly so that they do not have to be moved 2 times.
This is the reason for the great price!!
My customer is moving to a new building and if the machines are not sold by the first week in December they will be moved here to my facility in South Carolina this could add more shipping depending where the machines are sold.
Also I will be at the building where the machines are located presently at the end of November.
I will be disconnecting them and getting them ready for shipment.
The machines are currently connected to 480V 3 phase and have full isolation step down transformer to 380 3 phase. That would go with the machines if this meets your requirements.
If you have any other power you will need the appropriate transformer to get to the standard Deckel input power of 380V 3 phase.
I do have in stock a brand new Bruce Electric tranformer 220V up to 380v for sale.
Regards
DD
Old 11-06-2007, 09:52 AM
Hello Guys,
Just an update the FP3NC has been sold.
Regards
DD
Jog Controls dafowfidy Mach Mill 2 03-21-2007 05:01 PM
heidenhain controls Dar Bridgeport and Hardinge Mills 6 02-21-2007 07:50 PM
Building CnC Controls? How? ZAM Open Source Controller Boards 3 10-13-2006 02:59 PM
Controls Chuck Pool General CNC (Mill and Lathe) Control Software (NC) 7 02-23-2006 12:49 PM
