Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills
Deckel, Maho, Aciera, Abene Mills Discuss European "Deckel type" mills. Abene here!
  #85   Ban this user!
Old 12-09-2009, 03:38 AM
smoregrava's Avatar
smoregrava is on a distinguished road
No results. Have replaced all Ic's on card 1 and many on card 2 but still same problem. So still have some hour's with testing before It's up an working again.
  #86   Ban this user!
Old 12-09-2009, 03:55 AM
AndreasL is on a distinguished road
Sad to hear that Arild.
But good to hear its at least progress.
Keep up and you will get there.
If anything, give me a "pling".
  #87   Ban this user!
Old 06-21-2011, 05:36 PM
smoregrava's Avatar
Hi I have now manage to find a new AC spindle motor and I have upgraded to a newer Maho 432 controll. The machine started up nice and I have entered parameters ( Had to guess on some because There is many parameters in the new controll that I did not have)
But in the startup prosess there seems to be a problem with the IO card. When I start up the controll does some test all is passed except the I/O that gets No responce. I have not changed the card after I changed the controll.
the old I/O card has a diagnostics card connected. The new card seems a little different. There is no diagnostics. Maybe this new I/O card has diagnostic integrated
When I go into the PLC I/O screen. I see that it happends a lot on the inputs when I press the hydraulic button. But nothing happend on the outputs. Output 17 seems to be high all the time. But that seems a little strange. Does anyone know if I have to change the IO card when I switch to a newer controll?
ID:	136888   Click image for larger version
ID:	136889   Click image for larger version
Maho MH 400P fidibus42 Deckel, Maho, Aciera, Abene Mills 5 06-17-2008 12:30 AM
Maho 650 - CNC 532 Philips nylas Deckel, Maho, Aciera, Abene Mills 0 01-13-2007 12:41 PM
Maho 800 E communication question gv71 Deckel, Maho, Aciera, Abene Mills 0 01-11-2007 09:32 AM
MAHO Information Bearing Deckel, Maho, Aciera, Abene Mills 4 10-13-2006 01:42 PM
MasterCam and a Maho 700S carmijo Mastercam 1 09-07-2005 08:06 AM
