Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills
Deckel, Maho, Aciera, Abene Mills Discuss European "Deckel type" mills. Abene here!
Old 05-18-2007, 02:47 AM
rajappa is on a distinguished road
Deckel Maho DMC 70V with Dialog 112 control
Parameters for Deckel Maho DMC 70V with Dialog 112 got erased. I do not know the procedure and operation for entering parameters. The machine manuals do not give information on this. Can anybody give details ? After power on, display gets on and cycle stop button is always on even after all the emergency pushbuttons are released.
R.Rajappa
Offline
Old 12-29-2010, 12:04 PM
black is on a distinguished road
hi,
I got the same problem. Could you solve your problem ?? If yes, what is the procedure.
S.Black
R.Rajappa
Offline
Old 02-21-2011, 08:01 PM
qtmachining is on a distinguished road
i am just getting into DMG 5axis and was looking at DMU50V and DMU70V. Could you please let me know if this is a true 5 axis machine with Mill Plus control? is it very hard to find mastercam post for it?
Sorry i couldn't answer your question and waste your time on my own question. Appreciate for all the help.
Old 04-21-2011, 12:03 AM
Big Daddy is on a distinguished road
I’m really leaning toward a Dekel Maho monoBlock but that was one of my first concerns I run FeatureCam all the post processors are there. For the rest of you guys are you running the Heidenhain 530 controls?
Old 05-18-2011, 10:32 PM
pper is on a distinguished road
Hi, run a DMU 50 and a 70 and both of them are 3+2 machines no simultaneus on my models, however I know they do sell both models with full 5 axis, last year is the first year for simultaneus on the 50 I think. As far as the mastercam post I'm not sure, I use Camtool which has a 5 axis virsion that has a hiedenhien post processor. But even then I had to tweek quite a few things to get it to work properly.
Old 11-28-2011, 03:44 PM
technocenter is on a distinguished road
DMC 100V with Dialog 112
hello can somebody tell me about lubrication setting of the axis
Machine has Dialog 112 control
E-cabinet has mitsubushi units.
Some one told me the setting of lubrication can not be setted.
Machine gives a puls every 4 hours.
I can give manually puls on operation panel so i know the pump is working OK.
Can someone tell me if there is a parameter and how to change this one
Maho 700c control upgrade deckeldoctor Deckel, Maho, Aciera, Abene Mills 2 02-21-2010 12:45 PM
Deckel Maho DMC 63V Z axis intermittent drop.................need help alimansyah Deckel, Maho, Aciera, Abene Mills 13 10-15-2008 11:41 AM
deckel fb4 dialog 1 control SCHEMATICS LTD. Deckel, Maho, Aciera, Abene Mills 4 08-17-2007 01:33 PM
dialog box pminmo Suggestions for the CNCzone.com site. 1 08-03-2004 08:08 AM
Dialog Digits MikeT BobCad-Cam 2 03-02-2004 09:07 AM
