| Deckel, Maho, Aciera, Abene Mills Discuss European "Deckel type" mills. Abene here! |
| Hi I am programming post processors and encountered a challenge with this machine. This is a five axis machine with b-axis (head) and c-axis(table). The postprocessor drives a machine model in the cad/cam system. I used the center of the table as reference in my machine model. When they put an actual part on the real machine the part is not exactly the same way positioned i.e. the part is translated. I intended to have the nc-program cope with this offset. When I have a combination of b and c the spatial plane function does the job properly. However, if I only have a c-axis rotation I cannot seem to get it to work. The program below is one of my test programs. It is a block from which one edge is milled under different orientations 0 90 180 270 and two debur paths. This does not work according to the operator hopefully somebody is willing to share how to solve this challenge. Thanks, Jelmer 0 BEGIN PGM PROGRAM MM 1 ; MILL_CONTROL 2 ; PLANAR_MILL 3 CYCL DEF 247 DATUM SETTING ~ Q339=1 ; DATUM NUMBER 4 BLK FORM 0.1 Z X0.0 Y0.0 Z-20. 5 BLK FORM 0.2 X100. Y100. Z0.0 6 FN 0: Q8=250.00 ; Engage XY-feedrate 7 FN 0: Q9=250.00 ; Cutting feedrate 8 FN 0: Q10=250.00 ; Engage Z-feedrate 9 TOOL CALL 0 Z S0 ; ST20-UL55-SL38-WD20 10 CYCL DEF 7.0 DATUM SHIFT 11 CYCL DEF 7.1 X0.0 12 CYCL DEF 7.2 Y0.0 13 CYCL DEF 7.3 Z0.0 14 L Z-100. B0.0 R0 F MAX M91 15 L C0.0 R0 F MAX M91 16 L Z-50. B0.0 R0 F MAX M91 17 L C0.0 F MAX 18 L X58. Y65.745 F MAX M3 19 L Z220. F MAX 20 L X58. Y65.745 C0.0 F MAX 21 L Z220. B0.0 F MAX 22 L Z203. F MAX 23 L Z200. FQ10 M8 24 CC X62. Y60. 25 C X55. Y60. DR+ FQ8 26 L Y-48. FQ9 27 CC X62. Y-48. 28 C X58. Y-53.745 DR+ 29 L Z220. F MAX 30 ; PLANAR_MILL_COPY 31 L Z-100. B0.0 R0 F MAX M91 32 L X1050. Y797. R0 F MAX M91 33 L R0 F MAX M91 34 CYCL DEF 7.0 DATUM SHIFT 35 CYCL DEF 7.1 X0.0 36 CYCL DEF 7.2 Y0.0 37 CYCL DEF 7.3 Z0.0 38 CYCL DEF 247 DATUM SETTING ~ Q339=1 ; DATUM NUMBER 39 ; read preset table 40 FN 18: SYSREAD Q30 = ID220 NR2 IDX1 41 FN 18: SYSREAD Q31 = ID220 NR2 IDX2 42 FN 18: SYSREAD Q32 = ID220 NR2 IDX3 43 ; assign rotation angle 44 FN 0: Q33 =0.0 45 ; calculate cosine and sine 46 FN 6: Q34 = SIN +Q33 47 FN 7: Q35 = COS +Q33 48 ; calculate products 49 FN 3: Q36 = +Q30 * +Q35 50 FN 3: Q37 = +Q31 * +Q34 51 FN 3: Q38 = -Q30 * +Q34 52 FN 3: Q39 = +Q31 * +Q35 53 FN 1: Q40 = +Q36 + +Q37 54 FN 1: Q41 = +Q38 + +Q39 55 ; add to existing fixture offset 56 FN 1: Q42 =45. + +Q40 57 FN 1: Q43 =6. + +Q41 58 FN 2: Q44 = +Q42 - +Q30 59 FN 2: Q45 = +Q43 - +Q31 60 FN 0: Q46 =200. 61 CYCL DEF 7.0 DATUM SHIFT 62 CYCL DEF 7.1 X+Q44 63 CYCL DEF 7.2 Y+Q45 64 CYCL DEF 7.3 Z+Q46 65 L Z-50. B0.0 R0 F MAX M91 66 L C0.0 F MAX 67 L X13. Y59.745 F MAX 68 L Z20. F MAX 69 L F MAX 70 L Z3. F MAX 71 L Z0.0 FQ10 72 CC X17. Y54. 73 C X10. Y54. DR+ FQ8 74 L Y-54. FQ9 75 CC X17. Y-54. 76 C X13. Y-59.745 DR+ 77 L Z20. F MAX 78 ; PLANAR_MILL_COPY_1 79 L Z-100. B0.0 R0 F MAX M91 80 L X1050. Y797. R0 F MAX M91 81 L R0 F MAX M91 82 CYCL DEF 7.0 DATUM SHIFT 83 CYCL DEF 7.1 X0.0 84 CYCL DEF 7.2 Y0.0 85 CYCL DEF 7.3 Z0.0 86 CYCL DEF 247 DATUM SETTING ~ Q339=1 ; DATUM NUMBER 87 ; read preset table 88 FN 18: SYSREAD Q30 = ID220 NR2 IDX1 89 FN 18: SYSREAD Q31 = ID220 NR2 IDX2 90 FN 18: SYSREAD Q32 = ID220 NR2 IDX3 91 ; assign rotation angle 92 FN 0: Q33 =270. 93 ; calculate cosine and sine 94 FN 6: Q34 = SIN +Q33 95 FN 7: Q35 = COS +Q33 96 ; calculate products 97 FN 3: Q36 = +Q30 * +Q35 98 FN 3: Q37 = +Q31 * +Q34 99 FN 3: Q38 = -Q30 * +Q34 100 FN 3: Q39 = +Q31 * +Q35 101 FN 1: Q40 = +Q36 + +Q37 102 FN 1: Q41 = +Q38 + +Q39 103 ; add to existing fixture offset 104 FN 1: Q42 =-6. + +Q40 105 FN 1: Q43 =45. + +Q41 106 FN 2: Q44 = +Q42 - +Q30 107 FN 2: Q45 = +Q43 - +Q31 108 FN 0: Q46 =200. 109 CYCL DEF 7.0 DATUM SHIFT 110 CYCL DEF 7.1 X+Q44 111 CYCL DEF 7.2 Y+Q45 112 CYCL DEF 7.3 Z+Q46 113 L Z-50. B0.0 R0 F MAX M91 114 L C270. F MAX 115 L X-59.745 Y13. F MAX 116 L Z20. F MAX 117 L F MAX 118 L Z3. F MAX 119 L Z0.0 FQ10 120 CC X-54. Y17. 121 C X-54. Y10. DR+ FQ8 122 L X54. FQ9 123 CC X54. Y17. 124 C X59.745 Y13. DR+ 125 L Z20. F MAX 126 M140 MB MAX 127 PLANE RESET STAY 128 ; PLANAR_MILL_COPY_2 129 L Z-100. B0.0 R0 F MAX M91 130 L X1050. Y797. R0 F MAX M91 131 L C0.0 R0 F MAX M91 132 CYCL DEF 7.0 DATUM SHIFT 133 CYCL DEF 7.1 X0.0 134 CYCL DEF 7.2 Y0.0 135 CYCL DEF 7.3 Z0.0 136 CYCL DEF 247 DATUM SETTING ~ Q339=1 ; DATUM NUMBER 137 ; read preset table 138 FN 18: SYSREAD Q30 = ID220 NR2 IDX1 139 FN 18: SYSREAD Q31 = ID220 NR2 IDX2 140 FN 18: SYSREAD Q32 = ID220 NR2 IDX3 141 ; assign rotation angle 142 FN 0: Q33 =180. 143 ; calculate cosine and sine 144 FN 6: Q34 = SIN +Q33 145 FN 7: Q35 = COS +Q33 146 ; calculate products 147 FN 3: Q36 = +Q30 * +Q35 148 FN 3: Q37 = +Q31 * +Q34 149 FN 3: Q38 = -Q30 * +Q34 150 FN 3: Q39 = +Q31 * +Q35 151 FN 1: Q40 = +Q36 + +Q37 152 FN 1: Q41 = +Q38 + +Q39 153 ; add to existing fixture offset 154 FN 1: Q42 =-45. + +Q40 155 FN 1: Q43 =-6. + +Q41 156 FN 2: Q44 = +Q42 - +Q30 157 FN 2: Q45 = +Q43 - +Q31 158 FN 0: Q46 =200. 159 CYCL DEF 7.0 DATUM SHIFT 160 CYCL DEF 7.1 X+Q44 161 CYCL DEF 7.2 Y+Q45 162 CYCL DEF 7.3 Z+Q46 163 L Z-50. B0.0 R0 F MAX M91 164 L C180. F MAX 165 L X-13. Y-59.745 F MAX 166 L Z20. F MAX 167 L F MAX 168 L Z3. F MAX 169 L Z0.0 FQ10 170 CC X-17. Y-54. 171 C X-10. Y-54. DR+ FQ8 172 L Y54. FQ9 173 CC X-17. Y54. 174 C X-13. Y59.745 DR+ 175 L Z20. F MAX 176 M140 MB MAX 177 PLANE RESET STAY 178 ; PLANAR_MILL_COPY_3 179 L Z-100. B0.0 R0 F MAX M91 180 L X1050. Y797. R0 F MAX M91 181 L C0.0 R0 F MAX M91 182 CYCL DEF 7.0 DATUM SHIFT 183 CYCL DEF 7.1 X0.0 184 CYCL DEF 7.2 Y0.0 185 CYCL DEF 7.3 Z0.0 186 CYCL DEF 247 DATUM SETTING ~ Q339=1 ; DATUM NUMBER 187 ; read preset table 188 FN 18: SYSREAD Q30 = ID220 NR2 IDX1 189 FN 18: SYSREAD Q31 = ID220 NR2 IDX2 190 FN 18: SYSREAD Q32 = ID220 NR2 IDX3 191 ; assign rotation angle 192 FN 0: Q33 =90. 193 ; calculate cosine and sine 194 FN 6: Q34 = SIN +Q33 195 FN 7: Q35 = COS +Q33 196 ; calculate products 197 FN 3: Q36 = +Q30 * +Q35 198 FN 3: Q37 = +Q31 * +Q34 199 FN 3: Q38 = -Q30 * +Q34 200 FN 3: Q39 = +Q31 * +Q35 201 FN 1: Q40 = +Q36 + +Q37 202 FN 1: Q41 = +Q38 + +Q39 203 ; add to existing fixture offset 204 FN 1: Q42 =6. + +Q40 205 FN 1: Q43 =-45. + +Q41 206 FN 2: Q44 = +Q42 - +Q30 207 FN 2: Q45 = +Q43 - +Q31 208 FN 0: Q46 =200. 209 CYCL DEF 7.0 DATUM SHIFT 210 CYCL DEF 7.1 X+Q44 211 CYCL DEF 7.2 Y+Q45 212 CYCL DEF 7.3 Z+Q46 213 L Z-50. B0.0 R0 F MAX M91 214 L C90. F MAX 215 L X59.745 Y-13. F MAX 216 L Z20. F MAX 217 L F MAX 218 L Z3. F MAX 219 L Z0.0 FQ10 220 CC X54. Y-17. 221 C X54. Y-10. DR+ FQ8 222 L X-54. FQ9 223 CC X-54. Y-17. 224 C X-59.745 Y-13. DR+ 225 L Z20. F MAX 226 M140 MB MAX 227 PLANE RESET STAY 228 ; PLANAR_MILL_COPY_COPY 229 L Z-100. B0.0 R0 F MAX M91 230 L X1050. Y797. R0 F MAX M91 231 L C0.0 R0 F MAX M91 232 CYCL DEF 7.0 DATUM SHIFT 233 CYCL DEF 7.1 X0.0 234 CYCL DEF 7.2 Y0.0 235 CYCL DEF 7.3 Z0.0 236 CYCL DEF 247 DATUM SETTING ~ Q339=1 ; DATUM NUMBER 237 ; read preset table 238 FN 18: SYSREAD Q30 = ID220 NR2 IDX1 239 FN 18: SYSREAD Q31 = ID220 NR2 IDX2 240 FN 18: SYSREAD Q32 = ID220 NR2 IDX3 241 ; assign rotation angle 242 FN 0: Q33 =180. 243 ; calculate cosine and sine 244 FN 6: Q34 = SIN +Q33 245 FN 7: Q35 = COS +Q33 246 ; calculate products 247 FN 3: Q36 = +Q30 * +Q35 248 FN 3: Q37 = +Q31 * +Q34 249 FN 3: Q38 = -Q30 * +Q34 250 FN 3: Q39 = +Q31 * +Q35 251 FN 1: Q40 = +Q36 + +Q37 252 FN 1: Q41 = +Q38 + +Q39 253 ; add to existing fixture offset 254 FN 1: Q42 =-45. + +Q40 255 FN 1: Q43 =-6. + +Q41 256 FN 2: Q44 = +Q42 - +Q30 257 FN 2: Q45 = +Q43 - +Q31 258 FN 0: Q46 =200. 259 CYCL DEF 7.0 DATUM SHIFT 260 CYCL DEF 7.1 X+Q44 261 CYCL DEF 7.2 Y+Q45 262 CYCL DEF 7.3 Z+Q46 263 L C180. F MAX 264 L X-45.456 Y-59.745 F MAX 265 L Z27.071 F MAX 266 PLANE SPATIAL SPA0.0 SPB-45. SPC180. MOVE DIST0.0 F9999. SEQ- TABLE ROT 267 L X-13. Y-59.745 Z51.284 F MAX 268 L Z3. F MAX 269 L Z0.0 FQ10 270 CC X-17. Y-54. 271 C X-10. Y-54. DR+ FQ8 272 L Y54. 273 CC X-17. Y54. 274 C X-13. Y59.745 DR+ 275 L Z51.284 F MAX 276 M140 MB MAX 277 PLANE RESET STAY 278 ; PLANAR_MILL_COPY_COPY_COPY 279 L Z-100. B0.0 R0 F MAX M91 280 L X1050. Y797. R0 F MAX M91 281 L C0.0 R0 F MAX M91 282 CYCL DEF 7.0 DATUM SHIFT 283 CYCL DEF 7.1 X0.0 284 CYCL DEF 7.2 Y0.0 285 CYCL DEF 7.3 Z0.0 286 CYCL DEF 247 DATUM SETTING ~ Q339=1 ; DATUM NUMBER 287 ; read preset table 288 FN 18: SYSREAD Q30 = ID220 NR2 IDX1 289 FN 18: SYSREAD Q31 = ID220 NR2 IDX2 290 FN 18: SYSREAD Q32 = ID220 NR2 IDX3 291 ; assign rotation angle 292 FN 0: Q33 =0.0 293 ; calculate cosine and sine 294 FN 6: Q34 = SIN +Q33 295 FN 7: Q35 = COS +Q33 296 ; calculate products 297 FN 3: Q36 = +Q30 * +Q35 298 FN 3: Q37 = +Q31 * +Q34 299 FN 3: Q38 = -Q30 * +Q34 300 FN 3: Q39 = +Q31 * +Q35 301 FN 1: Q40 = +Q36 + +Q37 302 FN 1: Q41 = +Q38 + +Q39 303 ; add to existing fixture offset 304 FN 1: Q42 =45. + +Q40 305 FN 1: Q43 =6. + +Q41 306 FN 2: Q44 = +Q42 - +Q30 307 FN 2: Q45 = +Q43 - +Q31 308 FN 0: Q46 =200. 309 CYCL DEF 7.0 DATUM SHIFT 310 CYCL DEF 7.1 X+Q44 311 CYCL DEF 7.2 Y+Q45 312 CYCL DEF 7.3 Z+Q46 313 L C0.0 F MAX 314 L X-8.686 Y59.745 F MAX 315 L Z27.071 F MAX 316 PLANE SPATIAL SPA0.0 SPB-45. SPC0.0 MOVE DIST0.0 F9999. SEQ- TABLE ROT 317 L X13. Y59.745 Z25.284 F MAX 318 L Z3. F MAX 319 L Z0.0 FQ10 320 CC X17. Y54. 321 C X10. Y54. DR+ FQ8 322 L Y-54. FQ9 323 CC X17. Y-54. 324 C X13. Y-59.745 DR+ 325 L Z25.284 F MAX 326 M140 MB MAX 327 PLANE RESET STAY 328 CYCL DEF 7.0 DATUM SHIFT 329 CYCL DEF 7.1 X0.0 330 CYCL DEF 7.2 Y0.0 331 CYCL DEF 7.3 Z0.0 332 L Z-100. B0.0 R0 F MAX M91 333 L X1050. Y797. R0 F MAX M91 334 L C0.0 R0 F MAX M91 335 ; CUTTING TIME CUTTING LENGTH TOOL TOOL NUMBER 336 ; ----------------------------------- 337 ; 3.49 MIN. 871.33 MM ST20-UL55-SL38-WD20 T0 338 ; TOTAL CUTTING TIME 3.49 MIN. 339 END PGM PROGRAM MM |
| FANUC 3M G54 OFFSET, H-OFFSET----Please help!!! | cjchands | Fanuc | 2 | 05-25-2009 12:22 PM |
| Datum Shift with TNC530 | Bubbles | General CNC (Mill and Lathe) Control Software (NC) | 1 | 07-20-2006 06:23 PM |
| Jaw turning fixture | emergent | General Metalwork Discussion | 2 | 09-18-2005 08:47 PM |
| WTH Corrupt fixture Offset!? | DareBee | Fadal | 3 | 07-15-2005 10:11 AM |
| Self centering fixture | Hack | Mechanical Calculations/Engineering Design | 18 | 07-13-2005 12:09 AM |
