05-25-2006, 03:42 AM
Originally Posted by andyt The %PM15 header is needed to load the program into the control, but once it's in the HD you can pull up in the editor and you see no %PM to delete. |
if you open the file in the text editor you can see and delete the %PM, the text editor is in the same pull down menu as were you can copy files and make dir's (control menu)
do you load your program in "cad-mode" in the auto menu?? that's needed for large programs, select cad-mode and then select your main program, this will only work if you delete the %PM line
you problably know that a doc file can't be loaded, it should be a PM file
__________________ http:\\www.adcos.nl |
