| Deckel, Maho, Aciera, Abene Mills Discuss European "Deckel type" mills. Abene here! |
Hey Guys, First post and begging for help already. We just got a used DMU 50V 5-axis with a Heidenhain/Millplus V400 controller donated to us. Not sure at this point if it was a good or bad thing. LOL! =) The boss and I have read the book that came with it and we are still lost. How do you load a program into this thing? We have a RS232 cable hooked up but it will not take any programs I send. We are using “Predator” to edit and send the program. The closest thing to getting any sign that the 50v is trying to receive a program is that we got a baud rate error on the 50’s screen. Other than that for all we know we might not even be in the right screen to receive a file. Any help would be greatly appreciated by me. Background if you want to read: I work for Lick Observatory. Our machine shop is located in Santa Cruz, CA on the campus of UCSC We build telescope instruments for the Keck Observatory’s Twin telescopes on the Big Island of Hawaii (where I’m from) and for Lick Observatory in the bay area of California. We use Surfcam for our programming needs. Other CNC equipment: Millltronics 3-axis mill and a Mazak 24”x48” lathe |
| Did you get it working? i have worked on a dmu 50 evolution with millplus control we used a program called cds lite that was giving to us by the service guy that set up the machine this program worked great.i might have a copy some where if your interested. Tom C. Last edited by tomc3700; 04-10-2006 at 04:21 PM. |
| Thanks for the ZIP file of cds lite I will try it on Monday If you wouldn't mind could you give me a step by step instruction on how to get to the correct screen in order to load a program? I believe this is half if not all our problem. The instruction book we got is horrible. Also what baud rate do you transfer with? 4800, 9600? Thanks again |
run cdslite.exe.Right click on the top windows bar go to settings all set up options are in there. It been 3 years since i have played with a maho so you just have to play with the settings, the machine has a user paramiter settings to.I do know that the cdslite was drag and drop. Sorry if i cant help anymore i am rustry.also read the readme file. Because you need a null modem cable.also read the help file.also you need a good post prosser, we used mastercam and a bought prosser from cimco it worked very well. you said you used surfcam i dont think its 5 axis compatible.if you need a good 5 axis guy let me know i have ran them for 4 years only problem is that i am in ny.i still can program 5 axis. Tom C. Last edited by tomc3700; 04-09-2006 at 02:42 PM. |
| So we did some testing and found the settings (baud rate and so on) we need to transfer the data. Now our problem is at the DMU50’s control. I don’t believe we are at the right location to receive a file from our desktop computer. I’m not even trying to load a large program. Really only trying to load 10 lines of code. Just trying to get it to accept the data. BTW We had Surfware/Surfcam make us a post processor for the machine. Thanks for the offer of a referral. |
Now that you have gotten your program loaded please try to use cdslite because you can do a lot with it. you can save all the system paramiters,tool offsets,work offsets and so on.I will be around hear if you need any more help just let me know. Tom C. |
| Well today I loaded a program I made and ran it. Woo Hoo! All 5-axis were moving. No tool holder as they were ordered a week+ ago and no sign of them yet. My next step is trying to figure out how to set the tool height. This will be a big learning process also I’m sure. Hope to get the idea of how to do it before the holders arrive. The manual is of no help really. So far everything I’ve learned has been by trail and error. Problem with this machine is if you take 1 step anywhere it is at lease 3 steps back to get to 0 again. What a pain, makes you want to give up fast! When I get more comfortable I will try cdslite for sure. Thanks again for everything. |
| Do you have a heidenhain programming manual? heidenhain.com has them downloadable. Someone might chime in here if a 5 axis machine reaquires different toolheight setting. An example of "A" way to set tool height. Load a [should be relatively short]tool into tool pocket 1 set the tool length in the tool table to 0[zero] touch the tool off on the part, or table or whatever you deem is your reference zero. in manual mode, hit the orange z key, set datum to 0[zero] or there is a datum set soft key, same difference. put a tool in any other pocket you please call that tool, and touch it onto the same surface. DO NOT zero the machine. go into the tool table and set the length of that tool to the number shown on the z readout, for instance 1.567". repeat for any other tools. The mahcine will now recognize zero to be the surface you chose and all tools can be used referenced to the same point 5 axis might be difference because the length to the articulation point might matter |
#10
| We have a Heidenhain/Millplus V400 controller I have been doing what you have suggested from late yesterday but as of now I am unable to save the info. This controller is strange. We have a Milltronics Partner II and it is so easy to setup tool “Z” zero points. No need to plug in offsets, just touch the part, zero tool 1 and repeat for the rest. |
#11
| Are you doing EXACTLY as I suggested or exactly as you would for the milltronics? note you do NOT zero any tool but the first and you must enter the tool table to set all the other tool lengths I am not familiar with the mill plus, only regular heidenhains, so there might be differences |
#12
| Yes "zero" tool 1 and then try to enter the offset/difference between where T1 is at zero and where T2 would be at zero. T1 L1" T2 L3" = offset of 2" Sound right to you? But I cant get the machine to remember what I enter No store button or anything |
