Did you get the HSC? Siemens or Heidenhain Control? Late reply I know
Hi guys
anyone working with or have experience with the above machine? would like to know what I'm getting into
regards
anilam
We just got HSC 55 linear with sinumerik 840D Solutionline.
Tomorrow we will make first chips on it i cant wait for it.
It is fast i know that one.
And it looks like a beauty.
I worked on Mori Seiki 4000 DCG (4 axis) and Huron KX8Five (5 axis) but this is a beast of a machine
That control is very powerful. You have so many options on the control for programming. I really like the FN Function programming and SL Cycles. Just hate having to put Z+195 FMAX M91 in for B axis approaches over 20degrees. I have a Engraving Macro if your doesn't have an Engraving cycle.
right here is the macro's I wrote over a year ago.
this is specific to my application and setup which is milling PET molds out of 7075 aluminium.
these macros measure & mill the block to size automatically. I've changed the ext to txt u can change it back to h.
DO NOT RUN THIS ON YR MACHINE AS THE DATUM POINTS ARE OUT AND YOU WILL CRASH YR MACHINE.
USE IT FOR REFERENCE / GUIDE ONLY.
