Results 1 to 4 of 4
Thread: Inductive Sensor for MH800C NJ2/4-5791-Y22929
    Sep 2010
    Our machine is down 4 days already and Maho is very slow in responding. I need the gripper open/close sensor from Pepperl + Fuchs NJ2/4-5791-Y22929. Is anybody selling it - used or new doesn't matter. We got to get the mill running.
    Dec 2003
    If this is a inductive sensor then you most likely can sub it, after the obvious size requirements you need the operating voltage, whether N.O. or N.C. and sink or source, if three wire.
    Aug 2004
    Is that a small rectangular prox switch? Go’s right it the gripper hand? If it’s the one I’m thinking of, its really odd in that it has two sensor faces and 2 outputs in the same switch. On out the end and one on the side.
    If that’s the one I’m thinking of, I had one fail years ago. Pepperl & Fuchs down here in Australia, wouldn’t sell me one. There was no stock any way, but they claimed it was made for exclusively for Maho.
    I fear that might still be the case. Putting any or all of that part number into the P & F search site, finds zero results.
    Pepperl+Fuchs North America - Industrial Sensors and Intrinsic Safety Equipment
    Regards Phil.
    Sep 2010
    I am gettng the spare part tomorrow - finally. Thank you for the input
  1. Need Help!- Using inductive sensors with Mach3 & C11
    By George in forum General Electronics Discussion
    Last Post: 05-05-2009, 06:49 PM
  2. New Machine Build- probotix to inductive prox sensor
    By xkadet in forum General Electronics Discussion
    Last Post: 04-13-2009, 11:00 PM
  3. non ARC height sensor
    By sunmix in forum General Electronics Discussion
    Last Post: 11-05-2006, 12:51 PM
  4. Inductive Proximity Sensors
    By nickfox in forum General Electronics Discussion
    Last Post: 09-06-2006, 10:15 PM
  5. Inductive Proximity Sensors-what are they?
    By Splint in forum General Electronics Discussion
    Last Post: 08-01-2004, 06:24 PM
