Results 1 to 4 of 4
Thread: Deckel FP4AT
    Feb 2011
    BiH
    Deckel FP4AT
    Hallo. I have a deckel fp4at,and it was working fine until a few weeks ago.The problem is with the z-axis,when I put the first piece into the clamping tool,i can finish it nicely,the measures are solid,but after some time the table its going down,and when i touch the piece with kantentaster,there is a diference,0,2-0,4 mm,sometimes even more.It loks like the table is going down,and after some time i get errors,and my table cant go in height like before,last time it was down for 100 mm.After i find the reference point it was ok,it can go in max. height,for some time,and then agin it goes down.It can go for a day sometimes eve a 5 mm,or more.Then I must find the reference point again. But the problem is left.If the table goes for a few times up and down,while I`m working the piece,i got problems,the piece is not in the required tolerance,measures are not good.I tried everything,but the problem remains.Please,did anybody have a similar problem,or can somehow help.I would appreciate it.Thanks!
    Sep 2009
    DK
    Have your read my topic ?
    http://www.cnczone.com/forums/deckel...epair_any.html
    It seems like we have the same problem. In my case the counter stick (measurement stick ?) on the z-axis is broken. I am looking for some do-it-yourself guides to repair it.
    Feb 2009
    Sounds like the Z scale. The best Deckel guy I know-
    Deckel Doctors-Don Sentner
    1-843-397-7607
    Obviously in the US, but he knows the old machines way better than DMG does here. Hopefully Mori Seiki will make things better for the US, but I doubt it. He usually has rebuilt parts in stock.
    Feb 2011
    BiH
    I tried to clean it,no use.I have the same problem with y-achse now,I dont know what to do.I think I`m going to test the scale,i found the firm that test it,if it`s broken,i will have to replace it!Dont know other wax,tried everything.
  1. Deckel FP5
    By debco99 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 05-19-2010, 04:09 PM
  2. Rotation Macro Needed for Deckel 63V & Deckel 50T
    By CNC_Dan in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 08-20-2009, 09:44 PM
  3. Deckel FP1 (CNC?)
    By stephaan in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 02-04-2008, 10:52 AM
  4. Deckel DMU 50V
    By andyt in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 05-25-2006, 04:42 AM
