Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills
Deckel, Maho, Aciera, Abene Mills Discuss European "Deckel type" mills. Abene here!
Old 11-16-2010, 03:29 AM
razor_amd's Avatar
razor_amd is on a distinguished road
Maho MH800P regulator scheme needed BBC Axodyn 05LE10d-E
Need electric scheme for MAHO's MH800p motor regulator board BBC Axodyn 05LE10d-E (GJR5 1064 00 R1 | 05 LE 10 d-E)
We can offer other schemes in exchange from various machines: MAHO, DECKEL, Micron and others.
Thanks in advance...
Old 11-16-2010, 03:38 AM
razor_amd's Avatar
Or if there is some experienced electronic to help us with our problem. When we start the motor by turning Potentiometer it starts but we cannot regulate its speed, it runs on same speed no matter how we turn the potentiometer and we cannot also shut it off with potentiometer turned to zero, the motor continues to run same speed. We need scheme to investigate where the problem is...
If someone can help we would be most grateful...
Old 11-19-2010, 04:07 AM
razor_amd's Avatar
We found problem and have repaired the board... SOLVED!!!
Old 01-27-2012, 08:14 AM
belmarx is on a distinguished road
¿WHAT ZONE OF THE BOARD REPAIRED? WE NEED A SAME PROBLEM
Needed Manual for Deckel Maho 63V vijayraghav22 Deckel, Maho, Aciera, Abene Mills 15 08-10-2011 12:43 AM
Maho MH800 E2, Machine Constants needed ffaspector Deckel, Maho, Aciera, Abene Mills 7 05-11-2011 07:40 PM
Maho MH800P I have a silly question. hrhoward Deckel, Maho, Aciera, Abene Mills 2 06-10-2009 02:46 PM
maho toolchanger help needed moldxman Deckel, Maho, Aciera, Abene Mills 2 10-15-2008 03:11 PM
Advice needed about maho 700 from 1978 Jeroenvanderloo Deckel, Maho, Aciera, Abene Mills 5 05-03-2006 11:45 AM
