Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills
Deckel, Maho, Aciera, Abene Mills Discuss European "Deckel type" mills. Abene here!
Old 06-08-2005, 09:29 AM
alimansyah is on a distinguished road
Question Deckel Maho DMC 63V Z axis intermittent drop.................need help
Could anyone here help me to solve the intermittent Z axis drop problem on DMC63V?
Mostly happened when doing manual setting (using handwheel) or when closing access door and press Feed Start. PM to my email is also welcome.
Thank's in advance.
Old 06-10-2005, 01:15 AM
Mouldmaker is on a distinguished road
Have you checked whether the lubrication system is working properly? It could be happpening due to lack of lubrication on that axis.
If not I suggest you contact your local DMG area service as it could be an electronics problems.
Old 02-24-2007, 04:58 PM
halitcan is on a distinguished road
Hi . We have same problem in Turkey. Could you share us how did you solved the problem.
Old 04-09-2007, 12:32 PM
Priyank Avhad is on a distinguished road
dear friend can u give me the exact extent of the drop you are facing....and also info regarding the condition of the machine
Old 04-21-2007, 06:16 PM
satneo is on a distinguished road
Dear sirs
We had same problem at plant and had the machine technicians called in and fixed the problem will have to look at th report
Old 06-03-2007, 11:20 AM
jay123esh is on a distinguished road
Deckel CNC FP3AB axis intermittent drop.................need help...also tall about this penal digrame...som problem in penal so i have penal digrame...
Old 05-07-2008, 05:21 PM
NicolasPaul is on a distinguished road
I have the same problem with my DMC 63V in Canada. If someone have a idea how to fix it I am very interesting. I ask DMG to repair it many time and they cannot do it...
If I find something, I share it with you...
Old 05-07-2008, 10:13 PM
thebodger@roger is on a distinguished road
This sounds like a counterbalance problem. When the doors are opened the servos are disconnected. This is done as a safety precaution, i guess it's required in europe. Meanwhile with the drives turned off, the axis can drift out of set position due to counterbalance imprefection. Upon re-energize of drives, i.e., closure of doors , the drives react due to a following error that was caused by the drift and therefore go into a small "hunting" condition which appears as a jump. This is unacceptable. I can't comment about DMG's response overseas, but the lads in the Canada office should be able to address this problem for you.
Old 05-12-2008, 07:56 PM
My CNC don't have a counterbalance system, according to the information I get up to now, they're a mechanic break include with the motor and the problem is related to the sefaty communication protocole with the drive. Sometime problem of communication ignitiate the emergency stop ant give the command to the brake with a delay (This is why it drop between 2 and 8 inches.
Old 08-21-2008, 10:03 AM
wilos is on a distinguished road
DMC 63v drop z_axis
can you Check all conector (power suply and encoder) motor_z may be they lose or have to change. and you can try bypass door always lock,ii there oke you can us dmg service to change contactor betwen door lock with er module starting.
  #11   Ban this user!
Old 09-08-2008, 01:50 PM
Jaswin is on a distinguished road
we had same problem in 1035v. We found that bolts between the ballscrew nut and Z axis slide to be loosened. We tighted those and applied some locite. It solved my problem of drifting of Zaxis.
  #12   Ban this user!
Old 09-24-2008, 04:54 PM
deckeldoctor's Avatar
deckeldoctor is on a distinguished road
Inspect the encoder cable for the Z axis. Check continuity of the cable from one end to the other.
Look carefully at the connector on each end, those connectors suck!!
The pins push back inside the connector and do not make contact with all the pins in the connector or they make minimal connection affected by vibrations and other influences.
I have fixed 3 machines with this solution.
Regards
DD
5th even 6th axis? how does it work ToMMY2ooo General Metal Working Machines 10 10-04-2004 04:58 PM
