Hey all. I am wondering... does anyone here know much about the Deckel Maho DMC 60T with MillPlus-IT control?
Here is my basic dilemma:
I run Vericut in my shop. I simulate all of the milling code that goes out to the machines in an effort to avoid smashing stuff. As such, I have a very pressing need to accurately model all of our machines, both physically and kinematically. I have some subroutines/logic direct from CGTech (producers of Vericut), but by no means all.
The thing is, when the G7 command is active in our Deckel, the travel limits are slightly different, depending on the actual angle of the mill head. What I need to know is what logic I would need to use in order to account for changing travel limits. I'm not sure if I'm just overthinking this, but any suggestions would be hugely appreciated. I'm tired of getting false overtravel alarms, or worse, missing overtravels that should be caught.
Thanks in Advance!
-Mike
Dear Sir,
How r u?
I have one CNC machine. Complete detail with model is given below:
Machine Model: 64V Linear.
Machine Maker: Deckel Maho
Machine controller: Heidenhein iTNC530
In this machine I m facing one problem of I leak Led at power supply UV 123. That problem solved and now I have new alarm on the machine.
When I ON the machine and after complete CNC system booting. Machine gave “relay ext. dc voltage missing”.
When I ON the drives the all drives gave READY green LED. But after few seconds all drives off and machine at LCD screen gave alarm of
C3B0 Motor X does not rotate or some times it’s gave C380 Motor X not controllable.
Please give me the technical guidance to resolve my problem. Drive model is UM113.
I have no any manual and electrical drawing.
Hope you give me positive response.
My email id is Subhani_engr1@yahoo.com
